Thread: Audi A3 8p concert sound system upgrade + speaker covers needed
Results 1 to 10 of 12
  1. Audi A3 8p concert sound system upgrade + speaker covers needed
    Sep 2011
    north yorkshire
    Audi a3 2004 3 door
    single din concert
    box standard audi speakers
    i want to upgrade my speakers to vibe slick and was wondering if i needed some mounting adaptors for them and i was wondering if it was all on CANBUS system,
    want some speaker covers as well, mainly 2 tweeter covers in bache and front near side door cover
    thank you
    46 Post(s)
    The car itself runs on the canbus system.
    No idea on the speaker upgrade but I'm sure it could be plug n play.
    User NHN will be able to advise better than me
  3. Re: Audi A3 8p concert sound system upgrade + speaker covers needed
    Sep 2011
    north yorkshire
    so is the sound system canbus?
    is there a way too find out on the back of the head unit?
    i know that the speakers are connected through plugs so i imagine that i should be able to cut through it and put spade connectors on the end but if it is canbus i wont be able to do this will i?
    thank you
  4. Re: Audi A3 8p concert sound system upgrade + speaker covers needed
    46 Post(s)
    The Sound System is a module in VCDS so I assume they are connected to the canbus and you can make coding changes too.
    Look on the sticker on the headunit to see if there is a CAN related diagram.
  5. Re: Audi A3 8p concert sound system upgrade + speaker covers needed
    Sep 2011
    north yorkshire
    label picture
  6. Re: Audi A3 8p concert sound system upgrade + speaker covers needed
    Sep 2011
    north yorkshire
    there is no wires for K-bus, DWA GND or bose, but not particually shore what to look for
  7. Re: Audi A3 8p concert sound system upgrade + speaker covers needed
    Sep 2011
    north yorkshire
    do any of them imply that it is canbus?
    46 Post(s)
    The radio itself is Canbus - although looking at the speaker outputs you should be alright although a PM to NHN would confirm things.
    1 1 0
  9. Re: Audi A3 8p concert sound system upgrade + speaker covers needed
    Jan 2012
    Coding Something
    Canbus is the networking system used to communicate between modules, send signals, the speakers arent part of this system & are either wired from the head unit or amp in the boot.
    You would need to take a door card of & test for fitting as it may well require an mdf bracket or the like, you'd need to pop radio out & check wiring to the speaker outputs to see what yours are spec'd for.
    1 1 0
  10. Re: Audi A3 8p concert sound system upgrade + speaker covers needed
    Sep 2011
    north yorkshire
    what would you suggest for a mounting adapter bracket; MDF or plastic?
  1. Audi Concert II speaker upgrade
    By Evolutionuk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-11-2010, 06:41 PM
  2. Question Can I upgrade my audi factory sound system (concert) to the B&O ??
    By bjohn in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-06-2009, 05:11 AM
  3. Audi A4 speaker impedance? 1999 1.9tdi concert (non-bose) system
    By fantasiagreen in forum In Car Entertainment
    Last Post: 06-01-2009, 10:40 AM
  4. Please Help want to upgrade audi concert on A3 to after market system as cheap as possible.
    By alitech in forum In Car Entertainment
    Last Post: 28-11-2008, 12:52 PM
  5. bose concert speaker upgrade
    By slickoneuk in forum In Car Entertainment
    Last Post: 23-06-2008, 07:25 AM
