Thread: Polo timing belt removal saga
  1. Polo timing belt removal saga
    Feb 2007
    I had a go at changing the timing belt of a 2001 Polo 1.4 16 V auto the oter day. after trying for a few hours without getting anywhere, I had to give up in despair !! Is there no way to remove the crankshaft pulley bolt without buying a tool VAG Sealey tool no VS12473 ? Also is it essential to remove the right hand mounting for replacing secondary belt tensioner ??
    I can't also figure out the size of the crank pulley bolt !! (20mm bihexagon socket seems a bit loose, is it 19mm ?).
    Any tip on this will be greatly appreciated.
    Best
    Roy
  2. Re: Polo timing belt removal saga
    Jul 2007
    Hello There,
    I dont really know your technical experience sir but i strongly advise you to get this cambelt change done correctly first time as a the cost of a failure will be horendessly expensive,Its best to invest a little now and not a lot later,if you are not sure get proffesional help
    Best Wishes
  3. Re: Polo timing belt removal saga
    Feb 2007
    Hello abermaster
    I agree - returning timing belt kit to GSF and getting it done by a professionals !! Belt looks like it is in good condition though as this 7 year old car has only done 27000 miles.
    thanks all
  1. timing belt again
    By smiglyy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-08-2007, 09:02 AM
  2. Polo Timing Belt
    By ciaranlan in forum Polo - Derby - Lupo - Fox
    Last Post: 12-06-2007, 11:49 AM
  3. Timing Belt
    By OllyA in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-01-2007, 12:04 AM
  4. Cam belt timing belt tip , general
    By Conradvw in forum Archive posts
    Last Post: 11-01-2007, 04:29 PM
  5. timing belt/ cam belt change
    By jonoallen in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-11-2006, 01:24 PM
