Thread: remote fob re-sync problem on audi a6 19tdi c5
Results 1 to 10 of 11
  1. remote fob re-sync problem on audi a6 19tdi c5
    Aug 2006
    i have replaced the battery in my keyfob and have tried to re sync it via the owners manual, ie press one of the buttons on the remote key,insert the key in the door and either lock or unlock the vehicle once, then underneath it said the re synchronisation should not take more than 1 minute.
    i have tried it a dozen times and it still wont work,the central locking works fine useing the key to lock and unlock the car but no joy using the keyfob.
    possibly a duff battery so i will try another.
    any advise welcomed
  2. Re: remote fob re-sync problem on audi a6 19tdi c5
    Have you put it in the right way up. Regards Peter
  3. Re: remote fob re-sync problem on audi a6 19tdi c5
    Aug 2006
    hi Peter. yes it goes in with the + facing downwards so i know thats right.
    Southern County Softy
    20 Post(s)
    Try turning on the ignition then pressing the buttons.
    follow me on twitter...kiteaudi...
    A4 2.5 tdi QS (mapped)
  5. Re: remote fob re-sync problem on audi a6 19tdi c5
    May 2012
    Glasgow
    My keys have never worked remotely during my ownership so interested in this, have replaced battery and tried all the reset methods???
  6. Re: remote fob re-sync problem on audi a6 19tdi c5
    johnm Guest
    Quote Originally Posted by mrnice View Post
    The answer to this issue on my car was a visit to the main dealer who remapped the keys to the car. It's happened twice in five years now.
  7. Re: remote fob re-sync problem on audi a6 19tdi c5
    Aug 2006
    i have tried to resync it as per the book,also with the key in the ignition and then press the buttons,central locking is all working fine by using the key in the lock,all this started when the carpet got wet from a blocked drain bung below the battery,so i am lost for any more ideas other than to take it to the main dearer and see what they want to sort it.
  8. Re: remote fob re-sync problem on audi a6 19tdi c5
    Now you tell us the CCM has been under water. Have you removed the CCM and dried it out and all the carpets and cable harnesses. Tell us what you have done.
    Regards Peter
  9. Re: remote fob re-sync problem on audi a6 19tdi c5
    Jul 2012
    Dorset
    I currently have the same problem Nigel. Underneath my passenger carpet front and back was a huge puddle of water. The water can come from three main sources ... 1. the drain holes under the battery clogg up with leaves and silt so the rainwater level rises until it breaches the pollen filter housing and runs straight down under the passenger carpet, 2. rainwater runs under the trim at the bottom of the windscreen straight onto the pollen filter (this was one of my sources as the bit of trim was cracked) and 3. the hose for the rear washer (if you have an Avant) becomes disconnected in the passenger footwell and screenwash/water floods out (this was my main cause).
    At the moment my interior and wiring is still drying in the sun. I tested the CCM on Friday but it still won't allow me to reset the keyfobs so I'll leave it a while longer to dry out.
    In the meantime I've bought the necessary parts needed to fix all the leak sources.
  10. Re: remote fob re-sync problem on audi a6 19tdi c5
    Aug 2006
    i was very lucky,my ccm was not wet inside the box as such,when i took it out only the main plug connector was wet and the main plug itself,i left the carpet up for about 4 days to dry out after soaking up the water in the carpet backing,i removed the passenger seat to get the carpet up right to the rear footwell,car is working fine now but only when i lock and ulock it using the doorlock,the alarm,central locking and the 15 second delay to open the other doors via ignition all works as it should,i will try and resync again in the next few days,will keep this page updated.
  1. Please Help remote fob re sync (have searched)
    By brokenroads in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2011, 06:28 PM
  2. Please Help Remote sync
    By spew in forum Touran - Sharan - Caravelle
    Last Post: 22-03-2011, 11:03 PM
  3. Please Help A4 keeps losing remote sync
    By julie99 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-07-2010, 08:09 AM
  4. Help! Key Fob Sync
    By Ross Stoddart in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-05-2009, 10:15 PM
  5. MK 4 Golf 2004 Remote Re-Sync Info Req
    By teapot in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2008, 09:31 AM
