Thread: v6 tdi intake manifold flap fault
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: v6 tdi intake manifold flap fault more problems please help
    manchester
    Car on tester again today and comes up with 00550 start of injection regulation 00550 - Ross-Tech Wiki any suggestions? Thank you
  2. Re: v6 tdi intake manifold flap fault more problems please help
    london/ UK
    Pump timing is out, get a good mechanic that knows how to work on these and has VCDS to adjust the pump: clockwise to advance and anticlockwise to retard the timing...
  3. Re: v6 tdi intake manifold flap fault more problems please help
    manchester
    Why would the timing be out?
  4. Re: v6 tdi intake manifold flap fault more problems please help
    london/ UK
    I don't know love- not a clairvoyant ! It could be that it wasn't set up properly from the start or the VP44 pump is on it's last legs and cannot hold timing anymore. Get it to someone that has fully registered VCDS and they know how to check and adjust timing, if it needs adjusting then adjust it a little and see how the car behaves !
  5. Re: v6 tdi intake manifold flap fault more problems please help
    manchester
    Thank you. Booked the car in at the local vw specialist. Im just trying t understand why its hapened since no work has been done on the car. Last cambelt done 40k ago
  6. Re: v6 tdi intake manifold flap fault more problems please help
    manchester
    Iv had the car on vcds and the mechanic said the pump is on the last legs. Although he reckons the car goes in limp mode due to an possible air leak. He couldn't investigate as it was to busy. Tried to find this air leak for the past three days using diffident techniques what I could think of, washing up liquid , easy start spray, smoke and couldn't find anything. I'm starting to doubt that is got an air leak. Car goes in limp mode soon as I select drive when the revs are droping without even moving.
  7. Re: v6 tdi intake manifold flap fault more problems please help
    #17
    london/ UK
    Can you get the car to N. London ? I could have a look at the car for you...
  8. Re: v6 tdi intake manifold flap fault more problems please help
    #18
    manchester
    Quote Originally Posted by adamss24 View Post
    Many many thanks for the offer. I'm in Manchester and will try to get it sort it round here. I got two weeks till i start my new job and hope is enough time. The mechanic is trying to find some space were to put my car and leave it with him for more investigations that's not gone happen till Thursday though. If anyone got any more ideas what I could try in the meantime I would appreciate. Specially if I miss anything with my air/vacuum leak search.
  9. Re: v6 tdi intake manifold flap fault more problems please help
    #19
    manchester
    Can anyone recomend a company who will recon the fuel pump?
  1. Intake Manifold Flap Fault - Clean/Replace and where?
    By timdave25 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-11-2012, 08:42 PM
  2. Intake manifold flap
    By john-mandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-12-2010, 11:48 PM
  3. Intake Manifold Flap Fault Codes and Cleaning
    By aceofharts414 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-11-2010, 09:44 PM
  4. Intake Manifold Flap (V157)
    By SebastianTDI140 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-06-2010, 08:07 PM
  5. 2.0 TDI Manifold flap fault Help
    By Chap in forum Golf MK5 - 2004 - 2009
    Last Post: 27-07-2008, 02:01 AM
