Thread: Cold start low revs
  1. Cold start low revs
    Aug 2007
    Hi new forum member with a request for help..
    , had my Passatt for over 4 years and never had a problem. Its a 97 1.8 petrol, but the last few days when starting from cold it initially only ticks over at about 600 revs rather than the normal 800 or so. This makes it appear to want to stall. As the temp rises so does the revs until it gets back to normal idle tickover and seems okay. Additional problem is under braking when you drop the clutch the revs drop to 600 or less and again appear to try to stall before recovering back up to 800. Appreciate any suggestions on what the potential problem/fix would be.
  2. Re: Cold start low revs
    Oct 2005
    Lutterworth
    Check the coolant temp sensor and clean the throttle body.
    Search the forum for details.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
  3. Re: Cold start low revs
    Aug 2007
    Tried searching on the forum but found nothing similar. Will have a look at the coolant temp sensor as you suggest.
    thanks.
  4. Re: Cold start low revs
    Southampton, UK.
    Quote Originally Posted by Taffy123 View Post
    There are plenty of threads... read this: https://www.vwaudiforum.co.uk/forum/s...ad.php?t=11966
  5. Re: Cold start low revs
    Aug 2007
    Hi herby0001, thanks for that thread link, seems I didn't quite work out the right wording for the search. Carbon build up in the throttle could be a good reason for what i am seeing, will go and work on that.
  1. low revs on cold start -golf mk3 1.8
    By noho in forum Golf MK3 - 1993 - 1999
    Last Post: 20-08-2009, 05:38 PM
  2. 1999 Passat 1.8T high revs on start up
    By whitejc in forum Passat - Archive Topics
    Last Post: 05-05-2007, 05:59 PM
  3. Passat TDI high revs on cold start
    By weaverus in forum Passat - Archive Topics
    Last Post: 28-02-2007, 03:37 PM
  4. Cold start vibration
    By fugly in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-01-2007, 11:59 AM
  5. 1998 110 TDI dies with revs when cold
    By Antony in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2006, 02:57 PM
