I am after some advice please.
I have a misfire/judder on idle right through the revs.
No fault codes
No Smoke
Camshaft & followers replaced (they were worn)
Injector wiring loom replaced
2x Injectors Recon'd 2x tested ok
New fuel filter
Going to try compression test aswell, but has anyone got any idea's on this as the failed parts that would usually cause this type of fault have been replaced but with no effect
Thanks in advance
