Thread: "Limp Mode"? A6 Avant 2002 2.5TDi 114kw
  1. "Limp Mode"? A6 Avant 2002 2.5TDi 114kw
    Jul 2008
    Purchased a A6 Avant 2002 2.5TDi 114kw a few months ago.
    My wife reported a problem several times where the car lost all power, it just idled, and the esp and ABS (think its the abs) lights came on.
    As this never happened to me I put it down to her not changing gears, from 4th to 3rd for example.
    Eventually I decided to try and replicate the problem and was able to do this by being in 3rd gear, not 2nd, while going up a hill and putting the throttle all the way down for about 5 seconds at about 15mph.
    The car just went into limp mode, still moving but could not accelerate no matter what gear I changed into.
    This also happened on the motorway at about 60mph whilst accelerating.
    To resolve the problem I have to turn the car off and on again!
    The codes below are a result of this occurring.
    Anyone got any ideas?
    Thanks in advance.
    Control Module Part Number: 4B1 907 401 D
    Component and/or Version: 2.5l/4VTEDC G000SG D04
    Software Coding: 01012
    Work Shop Code: WSC 02325
    Additional Info: 00004059 130 106JC150_1.V77691379191
    1 Fault Found:
    00777 - Accelerator Position Sensor (G79)
    27-10 - Implausible Signal - Intermittent
    Control Module Part Number: 4B0 614 517 G
    Component and/or Version: ABS/ESP front 1728
    Software Coding: 06455
    1 Fault Found:
    01314 - Engine Control Module
    79-10 - Please Check Fault Codes - Intermittent
  2. Re: "Limp Mode"? A6 Avant 2002 2.5TDi 114kw
    Dec 2009
    Birmingham UK
    My guess is you need a new throttle pedal. It has a built in potentiometer that measures the position of the throttle and then sends a signal to the engine control module. As it's a moving part they tend to wear out at the point of most use which is typically low speed/stop start throttle travel. I imagine the module couldn't square the throttle position with the speed of the car and just went into limp mode as a precaution. My Allroad had it replaced and from memory it was around £90 plus labour (not a big job). Best get a specialist to check it out for you though.
  3. Re: "Limp Mode"? A6 Avant 2002 2.5TDi 114kw
    london/ UK
    Where about's are you based ? The c5 platform behaves in a odd way when an overboost condition occurs. I would start by checking under the battery covers for water build-up, the water makes it's way inside the ECU box and the connectors corrode which can trigger the accelerator pedal code ! However the ABS/ESP warning light will not go on because of the accelerator pedal and it's un-related. If you're not far from London then i could scan it for you and check a few parameters which can narrow down the potential culprits ! Give me a ring on 07789912128 if you need more details...
    Chris.
  4. Re: "Limp Mode"? A6 Avant 2002 2.5TDi 114kw
    Jul 2008
    Thanks for the replies!
    Down the A22 in Sussex so not close to London.
    Have a eBay VAG scanner thingy so any help on what I should be scanning for, step-by-steps would be great.
    Will check water problem when it stops raining !
    Thanks again,
    Steve
  1. Q7 "Limp Mode"
    By Weeted in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 12-01-2012, 04:10 PM
  2. Please Help VW Golf Plus 2.0 GT TDI DSG"limp mode"
    By waffenman67 in forum Golf MK5 - 2004 - 2009
    Last Post: 31-12-2010, 09:11 PM
  3. Question "Limp Home Mode" when giving it welly?
    By constablechris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-05-2009, 11:06 PM
  4. Golf Gt Tdi 110 "limp Mode" Problem
    By jamesknoedl in forum Golf MK4 - 1999 - 2004
    Last Post: 28-10-2008, 05:00 PM
  5. "Charge Pressure Deviation" - Limp mode
    By devonutopia in forum Archive posts
    Last Post: 01-04-2007, 06:11 PM
