Thread: Metallic Vibrating noise from drivers side wheel arch / engine bay area
  1. Metallic Vibrating noise from drivers side wheel arch / engine bay area
    My 57 Jetta 20 TDi has recently developed an intermittent metallic vibrating or rattling from the front drivers side area. From inside the car it sounds as if it is coming from the engine bay near the wheel arch and bulk head. It goes away if I turn left and comes back if I turn right. It sounds like a heat shield rattling against the engine or exhaust as the pitch changes with the changes in engine rpm. I made a hard left turn 2 days ago just to see if it would make any rattle and it went away for the rest of my journey and for the following day. On the way to work this morning it came back, again sometimes when driving in a straight line, quite often when making right hand turns and never when making left hand turns.
    Is there a heat shield in this area that could be loose and moving with the direction of the car turning? Hass anyone else got any ideas or had the same noise?
    Any help would be appreciated.
    RP200
  2. Re: Metallic Vibrating noise from drivers side wheel arch / engine bay area
    Mar 2008
    Swindon
    Hi, I had a rattly type noise coming from underneath my 2007 Jetta which only occurred under acceleration. I got underneath and pushed hard with my hand against the exhaust heat shield, pushing and moulding it firmly up against the car's underside, away from the actual exhaust - that did the trick. I suspect yours is similar and perhaps the heatshield just needs a bit of bending and moulding away from anything too close.
  1. knock sound from front drivers side wheel area
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-06-2012, 06:14 PM
  2. Light metallic rattle from drivers front wheel area over bumps.
    By JamesSvr6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-04-2012, 10:12 AM
  3. Clicking Sparking Noise coming from Drivers side wheel arch.
    By afghandaz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-05-2010, 08:24 PM
  4. Buzzing metallic vibrating noise, I think from engine??
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 01-11-2009, 01:52 AM
  5. Question Power steering noise, leak, gaiter piston drivers wheel arch.
    By charcos in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2008, 11:31 PM
