Thread: Can't put my finger on this Tyre Related Issue, help
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: Can't put my finger on this Tyre Related Issue, help
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by yus786 View Post
    .....but has this a little bobble....
    Not sure what you mean by that? Sawtooth on the rears is usually indicated by a droning noise, with excessive wear on the inside of the tread, usually caused by misalignment (toe-out in this case), so get the rears aligned before, or when, you have new tyres.
    1996 Laguna 2.2D
    1977 MGB roadster
  2. Re: Can't put my finger on this Tyre Related Issue, help
    May 2010
    Bolton UK
    Thanks, yes will get them aligned and then replace the 2 back tyres
  3. Re: Can't put my finger on this Tyre Related Issue, help
    May 2010
    Bolton UK
    Got a mobile tyre guy coming Friday to align and fit 2 dunlop sport maxx rt for 285 all in.
  4. Re: Can't put my finger on this Tyre Related Issue, help
    May 2010
    Bolton UK
    Update
    New Tyres at rear, all 4 aligned. noise is still there.
    So must be bearing yes???
  5. Re: Can't put my finger on this Tyre Related Issue, help
    Apr 2007
    France
    12 Post(s)
    Update
    Did your man give you a print out of the alignment (before and after)?
    1996 Laguna 2.2D
    1977 MGB roadster
  6. Re: Can't put my finger on this Tyre Related Issue, help
    May 2010
    Bolton UK
    Quote Originally Posted by Quatrelle View Post
    Sorry no, it was a mobile fitter. Lack of knowledge on my behalf and didn't know to ask for one
    Mobile alignment? Is that even possible?
  8. Re: Can't put my finger on this Tyre Related Issue, help
    #18
    Sep 2008
    SE London
    Sawtooth on rears does indicate rear wheel alignment was out. Had this on my '06 Estate.
    But believe it's a seperate issue for the noise which I also thought was wheel bearing.
    Does yours creak when you go over speed bumps? Has your noise changed since you've had
    wheel alignment. Either in tone or when it happens and goes?
    I read the threads in here about control arms. Have a look? Changed my outer control
    arm bushes first (not the arms themselves, they're £151 each inc. VAT for VW part which has
    been uprated) and noise went. As did the creak
    Afterward another re-alignment was needed (making two, one before and one after) Had mine
    done on a Hunter-equipped laser station
    Thread here: there are others: https://www.vwaudiforum.co.uk/forum/s...t=control+arms
    Apr 2011
    N/A
    I would say its the bearing too! Sounds exactly like a shot bearing.
  10. Re: Can't put my finger on this Tyre Related Issue, help
    #20
    May 2010
    Bolton UK
    Quote Originally Posted by RichardSEL View Post
    Thread here: there are others: Creaky front suspension
    Hi there, no it doesn't creak on bumps. And the noise is the same since the alignment. More like a blub blub or a whoop whoop - difficult to explain
    So does look like the wheel bearing. Have a service due soon, will point it out to them
  1. Drivers door finger plate
    By Rav in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-03-2012, 06:23 PM
  2. brake issue related to pedal box - HELP!
    By fingarosa in forum Polo - Derby - Lupo - Fox
    Last Post: 13-02-2012, 01:32 PM
  3. finger print reader problems
    By anil patel in forum A8 - S8 - V8
    Last Post: 08-11-2011, 12:20 AM
  4. ESP light fault - related to tyre change?
    By southview in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-11-2008, 07:38 PM
  5. a4 error; finger pointing @ ??
    By nordica5 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-07-2007, 02:55 AM
