Thread: Indicators flashing too fast
Results 1 to 10 of 14
  1. Indicators flashing too fast
    Jul 2007
    Co Durham
    Hi. My indicators have just started flashing too rapidly on both sides. The Hazard appears OK. Any ideas what it could be? (C5 Allroad, 2002)
  2. Re: Indicators flashing too fast
    Mar 2011
    Clitheroe, England
    11 Post(s)
    And the repeaters are working ok too? Never heard of this, apart from when one of the bulbs is out obviously.
    The Only Way Is A6!
    46 Post(s)
    Quote Originally Posted by WesleyP View Post
    Is the stalk on or off or is it doing it without interaction?
  4. Re: Indicators flashing too fast
    Jul 2007
    Co Durham
    Repeaters look to be OK, and only flashing when indicators actuated...
  5. Re: Indicators flashing too fast
    Southern County Softy
    20 Post(s)
    I would suspect a faulty hazard switch, the relay is built in.
    A4 2.5 tdi QS (mapped)
  6. Re: Indicators flashing too fast
    Sep 2009
    Blandford, UK
    Agree with kite, i remember my allroad having similar symptoms, then intermittent faults, then indicators failed. Replaced the hazard switch (indicator and hazard relays are built into the switch)
  7. Re: Indicators flashing too fast
    Jun 2012
    Hingham, England
    Either a bulb is out or your hazard light switch is defective.
    Id suggest the former as when the switch fails, indicators usually don't work at all.
    Check all 6 bulbs and if all working, check the wattage.
    Hope this helps.
  8. Re: Indicators flashing too fast
    Dec 2009
    Birmingham UK
    I reckon you need a new relay as kite says. Mine went haywire and teh indicators just flashed madly and at different rates, hazards fine. It's easy to replace and sits behind the hazard warning button as it's an all-in one unit. Slides out and unplugs.
  9. Re: Indicators flashing too fast
    Jul 2007
    Co Durham
    Just changed the relay, it wasn't that, still the same on both sides. I think it may be to do with towbar twin socket wiring. There is a clicking sound coming from down near the nearside rear light, like a relay, and when I plug the caravan in, the lights are back to normal speed.
  10. Re: Indicators flashing too fast
    Jul 2007
    Co Durham
    Turns out it was something to do with what is called a 7 way Bypass Relay in caravan towbar wiring. A few shakes and it was sorted!
  1. Varying revs at fast idle ten flashing warning?
    By freddyuk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-02-2010, 11:45 AM
  2. Question drivers side indicators too fast
    By DropKickMurphy in forum Golf MK3 - 1993 - 1999
    Last Post: 20-07-2009, 12:10 PM
  3. Passat indicator light flashing fast
    By jeetkando in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-02-2008, 02:01 PM
  4. Indicators not flashing!
    By misswhiz in forum Audi A3 - Archive Topics
    Last Post: 22-06-2007, 11:05 AM
