Thread: Lights,indicators and wipers dont work when engine is running.
Results 1 to 10 of 10
  1. Lights,indicators and wipers dont work when engine is running.
    May 2010
    United Kingdom
    Hi everyone I need some help as I'm baffled my 1.8 a4 lights,indicators and wipers dont work whilst the engine is running. when the engine is switched off they all work fine, so it cant be a fuse blown. what I have found on the bank of relays under the steering wheel is the 4th terminal from the left are 3 black and yellow wires together. when the ignition is on there is power to them but when the engines running power is lost. unfortunately I dont know where these wires run to. Anybody got any ideas please.
  2. Re: Lights,indicators and wipers dont work when engine is running.
    Aug 2007
    Derbyshire
    I've seen similar - turned out to be the ignition switch. Wiggle the key a bit with the engine running and they might work. I'm sure I got the info from threads on here, so try a search.
  3. Re: Lights,indicators and wipers dont work when engine is running.
    134 Post(s)
    2016 Post(s)
    Yes the you included the headlights I was thinking a failed X circuit on the ignition switch.
  4. Re: Lights,indicators and wipers dont work when engine is running.
    May 2010
    United Kingdom
    Quote Originally Posted by 31satara View Post
    Thankyou for your help will give it a try.
  5. Re: Lights,indicators and wipers dont work when engine is running.
    Mar 2015
    Lytham st Anne's
    Did you ever get a fix for this I have the exact same problem now and need my car for work tomorrow night and obviously need my lights cheers
  6. Re: Lights,indicators and wipers dont work when engine is running.
    Jul 2007
    This was a problem for me back in 2008 but I still have the car and had many more problems since....yes to your question it is defiantly the Ignition Switch...
    It was a fault back in the day and Audi used to repair this problem free of charge at one time when it was realized there was a issue with it...some plastic bit kept on breaking so I think they changed it to metal...
    You have to take steering wheel and airbag off to get a it .....it lives at the side of the steering column ...
    I have a do-it-yourself guide somewhere I will look for it and post it for you...
  7. Re: Lights,indicators and wipers dont work when engine is running.
    Mar 2015
    Lytham st Anne's
    Cheers pal that would be great
  8. Re: Lights,indicators and wipers dont work when engine is running.
    Aug 2011
    Meath
    Meantime just rotate the key anti-clockwise a little to the ign setting this should enable the wipers, lights etc that don't have power during starting
  9. Re: Lights,indicators and wipers dont work when engine is running.
    Mar 2015
    Lytham st Anne's
    I've just been trying that and can get it to do anything ?? May just be me
  10. Re: Lights,indicators and wipers dont work when engine is running.
    Jul 2007
    Well there are a couple of DIY ones but I think the one I used explained it really well with all the pics as well just going to look for it now..
  1. vw passat indicators dont work alarm is armed
    By andylowde in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-11-2009, 09:46 PM
  2. Please Help Help windscreen wipers dont work
    By 808 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-10-2009, 04:24 PM
  3. Intermitent wipers/indicators/heater fan don't work (1996 1.8 petrol)
    By stewburt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2009, 03:35 PM
  4. Please Help High beam lights dont work. (A4 B6)
    By Zeb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2008, 10:06 PM
  5. Interior Lights dont work
    By GrahamO in forum Chat - Completely Off Topic
    Last Post: 23-02-2007, 11:45 PM
