Thread: Another EPB Question
  1. Another EPB Question
    Should it be possible to leave the car with the EPB off?
    I did this by accident the other day after moving the car around in my garage, and only noticed when the car started to roll on a slight incline. I thought that the EPB always came on when the ignition went off. I'm now wondering if there is a fault.
    Mikecb1
  2. Re: Another EPB Question
    Mar 2009
    York
    Quote Originally Posted by mikecb1 View Post
    Mikecb1
    AFAIK it is always a manual procedure. Many times I have parked up then felt the car roll slightly, before remembering to depress the button. Not sure if those with Autohold find that it will put the EPB on automatically when at a stop in the car park....
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  3. Re: Another EPB Question
    Norfolk
    Autohold will automatically put epb on after a short time.
    No autohold means no auto epb. You have to put it on with the button.
  4. Re: Another EPB Question
    OK that explains it. I have autohold and use it all the time. I've got used to it automatically setting the EPB when I switch off, open the door, or undo seatbelt. On the occasion in question I had got out of the car with the engine running, which caused the EPB to set automatically, and autohold top switch off. When I got back in the move the car a foot I had to manually release the EPB, and I didn't turn auto hold back on again. When I switched off the EPB didn't set (because I didn't have autohold on). All now clear.
    Mikecb1
  1. Question EPB / Rear Pad Change Question
    By AlfieAudiA3 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-05-2012, 04:42 PM
  2. EPB tool
    By team914 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 21-10-2011, 09:54 AM
  3. EPB Tool
    By DSG4ME in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-03-2011, 08:02 PM
  4. Question EPB motor
    By allymac in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-10-2010, 09:54 AM
  5. Important Passat EPB
    By Gerry T in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-08-2010, 05:37 PM
