Thread: Emissions Garage! warning message
Results 1 to 10 of 13
  1. Emissions Garage! warning message
    Feb 2010
    Nutfield, England
    Hi experts and others
    I posted earlier when I was unable to remove my inlet manifold. Now I have progressed but still have a warning light and message. I have reassembled after cleaning inlet manifold EGR valve and manifold flap. The car is a Sep 2006 Golf GT TDI with BKD engine.
    I have been given conflicting advice. The amber symbol described in the user manual as, “Exhaust gas warning lamp” is on all the time and each time the ignition is turned on “Emissions Garage!” is displayed for a few seconds. The car seems to be running normally. One reliable garage man has told me that after working on the problem the light will stay on until reset and I need to let the car have several periods of use before the sensors will decide if the problem has gone away. So I should drive the car then bring the car in to have the fault warning reset, and hope the light does not come on again. Another professional, associated with diagnostics, told me that the fault warning only needs resetting with safety items like airbags, and that in the case of engine matters, if the fault disappears the light goes out. Also he said that if I disconnect the battery, then reconnect, memory of this sort of fault would be wiped and so if the warning comes on before even starting the engine that suggests an electrical problem. Can anyone with knowledge or personal experience comment?
  2. Re: Emissions Garage! warning message
    2016 Post(s)
    What is the fault code number?
  3. Re: Emissions Garage! warning message
    Feb 2010
    Nutfield, England
    P0401 Exhaust gas recirculation flow: insufficient detected. This was done for me by a non VW specialist garage, but they seem like good guys!
  4. Re: Emissions Garage! warning message
    Dec 2011
    Richmond
    6 Post(s)
    Could be one of a few things. Might be the intake manifold flap failing and not closing when required by the egr, might be a split or loose vacuum hose to the egr, might be the fuse for the inlet manifold flap, might be the vacuum control box faulty.
  5. Re: Emissions Garage! warning message
    Feb 2010
    Nutfield, England
    Thanks, Vikingraider, for your suggestions. If it was the intake manifold flap not shutting,
    that would be when the ignition switch is turned off. So if the battery is disconnected for a few minutes, then reconnected turning the ignition switch on should not result in getting the warning and message, unless the fault is stored and only disappears when it is reset by a vcds device. This is something I am hoping to find out. I will re-check the vacuum hose but it looked ok. The user manual does not list a fuse for the inlet manifold flap, but discreetly refers to other fuses only changeable by a qualified dealership, and does not reveal their location. Can you tell me more? If the vacuum control box was faulty would I not get other fault codes? I only got the one.
  6. Re: Emissions Garage! warning message
    Dec 2011
    Richmond
    6 Post(s)
    The inlet manifold flap (IMF) serves 2 purposes. It closes fully to stall the engine when you turn off the ignition. It also closes partly when the ECU requests EGR function to cause a vacuum through the EGR system. Without this vacuum there'd be insufficient EGR flow, so if the teeth are breaking or sticking on the IMF mechanism then it won't pull enough EGR and will throw a fault. The stored fault code will remain until cleared by diagnostics.
    The fuse in the engine compartment also controls the aircon fans. I can't recall which one it is although on my Altea when I had this fault it wasn't blown anyway. You might try fuse numbers 5, 8, 22, and 24 as they seem to ring a bell for some reason. The fusebox is on top of the battery or over there somewhere.
    If there's a fault in the vacuum box (I've known it once before) then it might only affect certain functions. EGR is one of them.
  7. Re: Emissions Garage! warning message
    Feb 2010
    Nutfield, England
    Thanks for that Vikingraider. That's helpful and gives me some leads to work on...
  8. Re: Emissions Garage! warning message
    Dec 2011
    Richmond
    6 Post(s)
    Okay, had another check through my earlier posts on another forum, and I think the fuse is a 10amp, and number 8 in the fusebox to the right of the battery as you look at the engine bay from the front.
  9. Re: Emissions Garage! warning message
    2016 Post(s)
    Its behind relay 458 on early cars.
    2 0 0
  10. Re: Emissions Garage! warning message
    Feb 2010
    Nutfield, England
    Thank you for the fusebox information. My fusebox has slight differences from the photo but nevertheless all the fuses were OK. However I have made progress. I have just taken delivery of a Ross-Tech VCDS (£208 from Gendan Ltd). Before using this device I had a continuous display of the “Exhaust gas warning lamp” and every time the ignition was switched on “Emissions Garage!” would be displayed. This would come on before the engine ran so it had either to be an electrical fault or it was ‘locked’ into the memory.
    I connected the VCDS to laptop and car and got the following report:
    3 Faults Found:
    001025 - EGR System
    P0401 - 000 - Insufficient Flow
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 0
    Fault Frequency: 5
    Mileage: 144647 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:00:03
    Freeze Frame:
    RPM: 1512 /min
    Speed: 21.0 km/h
    Load: 23.1 %
    Duty Cycle: 14.6 %
    Duty Cycle: 100.2 %
    Mass Air / Rev.: 280.0 mg/str
    Mass Air / Rev.: 705.0 mg/str
    000258 - Mass Air Flow Sensor (G70)
    P0102 - 000 - Signal too Low - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 144719 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:01:33
    Freeze Frame:
    RPM: 1008 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Duty Cycle: 79.7 %
    Bin. Bits: 11000100
    Mass Air / Rev.: 370.0 mg/str
    Mass Air / Rev.: 0.0 mg/str
    012546 - Motor for Intake Manifold Flap (V157)
    P3102 - 000 - No Signal - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.24 V
    Bin. Bits: 00000100
    Torque: 0.0 Nm
    Torque: 351.4 Nm
    After noting the above I cleared all codes, and was pleased to find that the warning light and message had disappeared, and remained extinguished after a short journey. Earlier, when I took the car to a garage for a diagnostic check they only got the one code, the P0401. I may have induced the other 2 by experimentally turning on the ignition with plugs unplugged. If the warning message returns I will report further
    I will report if the warning returns
  1. Question Emissions - Garage!
    By the surfer in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-06-2011, 12:42 PM
  2. Possible Solution: Emissions Workshop message on dashboar
    By andrew_jmdata in forum Golf MK4 - 1999 - 2004
    Last Post: 12-12-2009, 03:07 PM
  3. emissions garage
    By codder in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-10-2009, 06:50 AM
  4. Emissions Workshop message
    By Llanesra in forum Golf MK5 - 2004 - 2009
    Last Post: 03-04-2009, 04:25 AM
  5. emissions garage??????
    By kerr01uk in forum Touran - Sharan - Caravelle
    Last Post: 22-03-2009, 05:46 AM
