Thread: Parking sensors no longer mute radio
  1. Parking sensors no longer mute radio
    Nov 2008
    I hope someone can help as I really can't work out what I've done! I have a 2008 A5 with Concert radio and factory fitted reverse parking sensors. Up until a few weeks ago, when I put it in reverse it would mute the radio down to an almost inaudible level but not any more. If I'm listening to Media (SD card) then it lowers the volume slightly, like 1 click on the volume control, but not at all on the radio. The manual implies I should change the "In Car Entertainment" volume on the volume settings, but that's already at the minimum (traffic is one above the minimum. GALA is set to 3). I've tried the "reset settings" option on the radio but it didn't make any difference. Can someone please tell me what button to push to get it back to how it was? I'm sure it's simple... Cheers, John.
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    You could try putting the car into reverse then using the volume knob to lower the volume to the desired level. If you're lucky, this will set the volume for when the parking sensors are active.
    Good luck!
    MF.
    Sent from my iPad using Tapatalk HD
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
    46 Post(s)
    Press Car then there should be a audi parking system submenu and adjust the buzzer volume - always something to try
  4. Re: Parking sensors no longer mute radio
    Nov 2008
    Thanks for the suggestions. Turning down the volume while in reverse just left it at the same lower volume when I went back to D. But a combination of turning up the "Traffic Announcement" setting under volume settings and turning up the buzzer volume seems to have got it back to nearly where it was before. Cheers, John.
  1. Parking Brake no longer releases automatically?
    By sunil1234 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-04-2010, 09:18 PM
  2. Replies: 1
    Last Post: 06-07-2009, 11:04 PM
  3. radio volume & parking sensors
    By Jop in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-05-2009, 07:15 PM
  4. DAB radio no longer displays track info
    By brantome in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-12-2008, 08:07 AM
  5. Bora Gama Radio Fault - Phone Mute
    By 2moreski in forum Bora - 1998 - 2005
    Last Post: 26-11-2008, 03:40 PM
