Thread: Loss of power and no brakes
Results 1 to 9 of 9
  1. Loss of power and no brakes
    May 2012
    Scarfskerry Highlands
    The car has developed a new fault no power, it feels like a straight 1.9 diesel, no pull up hills and no chance of overtaking.
    No EML showing
    Also when slowing down for a junction with the clutch in and slight braking, if you let off the brakes (clutch still in) then reapply there are no brakes you have to stand on the brake pedal like a Clydesdale to get it to stop.
    I have read many threads on this site about the power loss but none have mentioned the problem with the braking.
    Hopefully I can get the codes read later to day and will post them.
    Any thoughts most welcome.
    Nobby
  2. Re: Loss of power and no brakes
    Pembrokeshire
    22 Post(s)
    you have a vacuum leak. the turbo needs a vacuum to make it work as do your brakes, and it all comes from the same source (vacuum pump on back of engine, which is joined to the fuel pump and called a tandem pump).
  3. Re: Loss of power and no brakes
    Pembrokeshire
    22 Post(s)
    of course the pump may also be goosed, but check all the vacuum pipes first.
  4. Re: Loss of power and no brakes
    May 2012
    Cheers Zollaf, suns out, codes to be read at 11:30, 3mts of 3mm silicone vac pipe and a vac pump (hand held) in my hand, guess my day's planned.
  5. Re: Loss of power and no brakes
    Pembrokeshire
    22 Post(s)
    there will probably be an underboost code. there is a connection iirc on the back of the engine bay, drivers side that pulls apart.
  6. Re: Loss of power and no brakes
    May 2012
    Zollaf, just back, you ain't wrong on the codes, 17664 P1256 Engine Coolant Temperature (sporadic) sensor -G62 open/short to B+ and the second is 17946 P1556 Turbo boost sensor (sporadic) (A) circuit: control limit not reached.
    Will go and look for this iirc connector.
    Nobby
  7. Re: Loss of power and no brakes
    May 2012
    Zollaf your a star of the first order.
    Found the connector, right under the EGR valve actuator just where the vac pipe turns towards the barke servo, the thin plastic pipe had pulled out, how
    Anyway replaced the whole with a tad longer silicone pipe, and whilst I was at it I replaced all the cloth covered vac piping, bright blue pity the engine cover hides it.
    Took it for a spin, the cheese factor had returned, pulled like a train, brakes work perfect.
    Thanks again Zollaf
    0 2 0
  8. Re: Loss of power and no brakes
    May 2020
    stockport
    i two have this issue but with Waring of oil pressure low is it related?
  9. Re: Loss of power and no brakes
    Jun 2021
    Leeds, United Kingdom
    Quote Originally Posted by tomr10 View Post
    i to have the same issues as above with the low oil preasure and a chain type noise when car has been started cold, gonna check that iirc in 10 mins and come back with an answer
  1. Please Help Loss of power> smokey > then no smoke or power at all!! (VW Mk4 GT TDI 130)
    By v15hal in forum Golf MK4 - 1999 - 2004
    Last Post: 24-08-2012, 07:24 AM
  2. Please Help Intermittent loss of brakes and no power?
    By PassSPORT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2011, 09:50 PM
  3. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  4. Loss of power front brakes locked
    By skyblueeyes in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2009, 09:16 PM
  5. Please Help Drinking Oil - Loss Of Power - Loss Of Revs
    By mrmonk21 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-06-2008, 05:54 PM
