Thread: Part number help needed.
Results 1 to 10 of 14
  1. Part number help needed.
    Hi guys,I am having a fuel pressure problem with my 2005 2.0t fsi Quattro saloon. I ahve already replaced the fuel pressure sensor that had come up as a fault but i still have the engine light on. I am now going to replace the fuel filter and then if that doesn't work i am going to replace the in tank fuel pump. Does anyone know the part number of the fuel filter and the fuel pump?ThanksTim
  2. Re: Part number help needed.
    135 Post(s)
    2038 Post(s)
    Which engine code and is it the early or late 2005 face lift version?
  3. Re: Part number help needed.
    46 Post(s)
    I think A4 Lad had a similar problem - I remember reading it here Please Help G247 Fuel Pressure Sensor Help
    Although no idea if its related to your problem
  4. Re: Part number help needed.
    The engine code is BGB, and i'm not sure what you mean about being a face lift car. It's a B7 and it was first registerd in February 2005, is this any help?
  5. Re: Part number help needed.
    Thanks for the link, i have read it and thats why i'm starting with the filter then a pump.
  6. Re: Part number help needed.
    135 Post(s)
    2038 Post(s)
    The BGB was only used post facelift so it is the later version, which of the two fuel pumps do you want the part number of? The fuel filter is 4F0 201 511 E, £25 from Audi and located at the back of the car and if I remember rightly, a complete **** to get at being tight up against the side of the tank and chassis leg, certain versions are tucked so far away up at the side of the tank that I had to cut an M8 XZN tool down to have only a thin 10-mm across flats top surface so I could just about undo the bolt, for this reason the filter rarely gets changed.
  7. Re: Part number help needed.
    It's the in tank lift pump that I need. I'm getting a low pressure warning so the filter and pump are my first thoughts.
  8. Re: Part number help needed.
    May 2009
    Glasgow
    Have a look at the Cam follower for the High Pressure Fuel Pump located at the rear of the engine. These are prone to wear and when they do, they do not achieve the full stroke required for the pump to operate properly. this causes fuel starvation at higher revs. No harm in swapping it anyway, even if its not that bad. a badly worn follower can damage the Camshaft.
    Have a look at this.
    DIY: High pressure fuel pump removal/installation & cam/follower inspection | Volkswagen Rabbit/GTI/Jetta/GLI MkV DIY & FAQ#
    Roonster.
  9. Re: Part number help needed.
    135 Post(s)
    2038 Post(s)
    This failure is often due to the pump leaking petrol into the engine and washing the oil off of the cam follower.
  10. Re: Part number help needed.
    I had read about the follower and i was going to change it as a matter of course as the car has don 62000 miles now.
  1. Part number needed
    By Macdoon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-02-2012, 02:13 PM
  2. Question Part number needed
    By magus in forum Bora - 1998 - 2005
    Last Post: 08-02-2011, 06:56 PM
  3. part number needed please
    By 16v mad in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 15-04-2009, 12:33 PM
  4. Please Help Part number needed
    By smudge_don in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 29-12-2008, 06:25 PM
  5. Part Number Needed
    By hagis in forum Chat - Anything with wheels
    Last Post: 02-10-2008, 01:29 PM
