Thread: Flashing Glow plug light
  1. Flashing Glow plug light
    daled Guest
    I have a BRE coded 2.0TDi 170 q that has just had 70k major service, cambelt and water pump etc through a local InNdy
    Whilst driving home last friday my glow plug light started flashing and I think the car went into limp mode (No power). Turned off engine when I got home, turned it on again and the light had gone out
    When the service was done on Monday, diagnostics presented fault p0299 relating to under boosting turbo, fault traced to failed diverter valve so it was replaced
    Yesterday on the way home the light came on again, into limp mode, engine off and then on again and no light!!
    Is there anythng I need to be aware of or needs to be investigated with this issue, before I speak to my indy again
    Don't know if it's related but the injectors and loom were all replaced under Audi goodwill in September last year
    Any help appreciated
  2. Re: Flashing Glow plug light
    May 2007
    Hi just in case you still havent fixed yet, i had this problem & cause was faulty brake light switch cheap & easy to replace hope this helps
  1. Question Glow Plug Light flashing
    By carlo in forum Early Passat Forum - Pre 97
    Last Post: 17-03-2010, 09:15 AM
  2. Flashing Glow Plug Light??
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2009, 09:49 PM
  3. Flashing Glow plug light
    By Generic man in forum Golf MK4 - 1999 - 2004
    Last Post: 23-10-2009, 12:47 PM
  4. Glow Plug Light Flashing
    By mac78 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-12-2008, 01:41 PM
  5. flashing glow plug light
    By imanutter in forum The Commercial Range
    Last Post: 02-12-2007, 07:12 PM
