Thread: Brake Pad Warning?
  1. Brake Pad Warning?
    Jun 2008
    Hi Guys,
    My A4 is coming up to 4 years old and has done just over 36k. The brake pad warning light has started coming on intermittently. This seems very weird when the car just had a service a couple of weeks (and a couple of hundred miles) ago and the garage said the pads were fine. The outer pads all look ok but it's pretty much impossible to get at the inner ones without taking the wheel off.
    The problem is that we're driving to the Scottish Highlands at the weekend and I'm going to struggle to get it into the garage before then. Any views on whether this is likely to be a dodgy sensor rather than an actual problem and anything I can do to fix it check?
    Audi A4 (B9) Avant 3.0 TDI (272) Quattro with lots of toys
  2. Re: Brake Pad Warning?
    Aug 2010
    Leicester
    Quote Originally Posted by satsu View Post
    Hi Guys,
    Ah thanks, your question has partially answered one I've been meaning ot ask for a while ... what method does the A4 use for low pad detection? Is is the type with conducting wires in the pads, or just works by the fluid level getting low as the pads get further worn?
    2017 A5 sportback, 2.0TFSI, quattro, S tronic, S line, virtual cockpit, mythos black.
  3. Re: Brake Pad Warning?
    Sep 2008
    Berkshire
    I had an advisory from the garage that I would need front pads at the last service (29000miles-ish) and they said you have about 500 miles once the light is on. They didn't say if the light was permanent or intermittent though. I would expect permanent so can't offer any reason why yours is intermittent. I ran the car for another 4000 miles and then booked it in for new pads. The light still wasn't on but the garage decided I needed discs too! The discs were changed, but I made it clear to both Camberley Audi and Audi UK that I am unimpressed that the tyres are lasting longer than many parts on this car over its 3+ years, including: ignition switch, 2 different ECUs, aircon pressure switch, clutch, flywheel, door seals, and now the fuel filler lock. I'm wondering if any other manufacturer could actually do worse than this B8?
    A5 (Cabriolet) 2.0 TDI 177PS S-Line - Scuba blue, Technology pack (high), B&O soundsystem, Bluetooth (low), Heated seats, Autoglym life shine.
  4. Re: Brake Pad Warning?
    Mar 2010
    Cambridge
    Quote Originally Posted by markp306 View Post
    The joys of Cambridge Vindis Audi. I wouldn't touch them with a barge pole....
    My car has 102k on the clock, pads changed at approx 85k, still on the original discs...
    Audi A4 Avant (58) - 143 Tdi SE Manual - AMI and cruise
  5. Re: Brake Pad Warning?
    Aug 2007
    New Romney Kent
    An intermittent light would suggest either an iffy brake pad plug connection or low brake fluid.
    VCDS HEX-NET registered owner (Covers all VAG cars)
    PM me if you require scans or adaptations doing in S.E. Kent, can unlock SFD.
    Audi TTS 8S
    VW ID.3 Tour
  1. Question Brake Pad Warning system
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-10-2011, 08:06 AM
  2. Brake pad warning
    By Ratboy! in forum TT - 8N Forum - 1998 - 2006
    Last Post: 05-06-2010, 02:53 PM
  3. Brake pad warning light
    By avantscott in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-07-2009, 09:40 AM
  4. Brake Pad warning
    By johnm in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-07-2009, 09:52 AM
  5. Brake pad warning
    By t4driver in forum The Commercial Range
    Last Post: 01-04-2008, 04:20 PM
