Thread: Which Glow Plugs for 3.0TDI (BMK)
Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 75
  1. Re: Which Glow Plugs for 3.0TDI (BMK)
    #31
    Nov 2010
    Watford
    The ECP Beru glow plugs are GE115, 0 100 266 040 = ECP part 438 44 0015. Also I found on the box 15Nm torque. (A6 3.0tdi ASB 2006) Maybe ECP list A8 3.0tdi as a different part no?
    Audi Allroad 3.0tdi. Tiptronic. 12/12/2006. Full Phantom Black, 19" alloys, MMI high, Navigation, Phone prep, Heated sports seats with memory, Parking advanced with rear camera, Sunroof, Rear blinds.
  2. Re: Which Glow Plugs for 3.0TDI (BMK)
    #32
    Nov 2012
    Australia, Melbourne
    I know this sounds stupid, but where are the glow plugs? Anyone got real pics? Not illustrations please. i've seen plenty and they're all confusing... n00b :-(
  3. Re: Which Glow Plugs for 3.0TDI (BMK)
    #33
    Nov 2010
    Watford
    Cwizard, Under the "How to" threads look at my pictures for "Intake Manifold Replacement and Fix - 2.7 TDi + 3.0 TDi V6 Engines" it shows the glow plugs in the pictures, with the manifolds removed. That may help you. Obviously three on each bank with what looks like a mini spark plug lead attached.
  4. Re: Which Glow Plugs for 3.0TDI (BMK)
    #34
    Nov 2012
    How about do you go removing those rubber plug leads that are attached? I tried pulling them out i heard funny sounds and left it at that... pretty scared to be honest.
  5. Re: Which Glow Plugs for 3.0TDI (BMK)
    #35
    Nov 2010
    Watford
    They pull straight off. Can be tight, they do clip on to glow plug inside the cap. Just pull cap straight up and don't pull on the wires.
    1 1 0
  6. Re: Which Glow Plugs for 3.0TDI (BMK)
    #36
    Nov 2012
    I take it that to replace the glow plugs i have to remove inlet manifold??
  7. Re: Which Glow Plugs for 3.0TDI (BMK)
    #37
    Nov 2010
    Watford
    No no. Those pictures are just for reference. You don't need to remove the manifolds. See my previous post on fitting them!
  8. Re: Which Glow Plugs for 3.0TDI (BMK)
    #38
    Nov 2012
    coalville leicestershire
    You can buy special pliers for pulling the glow plug connectors.
    But on the ones that were very tight I used a piece of 2mm nylon cord, tied a slip knot over the wire, fed it down, pulled tight then pulled up. Worked a treat
    3 1 0
  9. Re: Which Glow Plugs for 3.0TDI (BMK)
    #39
    Jun 2006
    UK, Mids
    When the engine is hot, the rubber is more forgiving. Mine came off with pointy pliars and a bit or wiggling while pulling.
    I had to remove the two rear posts that hold the engine cover on so that the wiring loom brackets lift off.
    I used a deep 10mm socket (you can buy them specifically for glowplugs) and a bunch of cheap 1/4 inch extensions.
    A 'wiggle' extension that allows you to have the socket straight on the plug, but the entension and wrench at an angle is needed for at least one of the plugs, As I didn't have one, I found that popping the extension out of the socket and pushing it back in a small amount gave enough play.
    A spray brake cleaner, followed by a good dode of PlugGas helped release them and protect the threads, aerosol jet is best and the glow plugs are down in crevices.
    I used a 3/8 drive torque wrench with a 3/8 to 1/4 adaptor. Most torque wrenches start above 15Nm though so you may need a small one.
    VAG says install the plugs dry, and BERU says use their special copper-free anti sieze. I used a feint smear of ceratec brake grease.
    I only torqued mine to 10-12Nm as I could tell it was plenty and they were lubricated which can give a lower reading.
    If I did it again, I would use an air duster to blow out the holes so there is lower risk of debris on the mating flange down inside.
    Audi A8 - 2015 - 3.0TDI
    3 2 0
  10. Re: Which Glow Plugs for 3.0TDI (BMK)
    #40
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by snapdragon View Post
    I know a bit pricey now@£75... but I bought mine a while ago and got to admit the Halfords advanced one is great to use... does 8 -60 nm... Link:- Halfords Adv. 3/8 Torq.Wrench
    For heavier duty situations I've found the Link:- Challenge 1/2 Torq.Wrench maxes out at 240nm IIRC... used when did brake callipers,etc...
    IIRC it is same as Sliverline one which I've seen on ebay for about £20...
    I'm bit of sucker for tools ...
    Link:- Torque wrenches tested | Auto Express
  1. Question When do you change glow plugs in a 2.0TDI ?
    By nowa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-02-2012, 10:48 AM
  2. Replies: 6
    Last Post: 08-02-2011, 03:28 PM
  3. Glow Plugs
    By dawndriver in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-10-2010, 02:43 PM
  4. Glow plugs
    By telboblock in forum New Member Introductions
    Last Post: 05-05-2010, 09:02 AM
  5. Glow plugs, which ones?!
    By siman05 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-01-2010, 02:17 PM
