Thread: Which Glow Plugs for 3.0TDI (BMK)
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 75
  1. Re: Which Glow Plugs for 3.0TDI (BMK)
    #21
    Mar 2008
    Herts
    Quote Originally Posted by gupsterg View Post
    I'm thinking at some point to do mine as they seem low cost item and good to replace if they are being used until coolant reach (x) temp/time elapsed...
    A question for fieldy/bops6 are you guys replacing because of faults or preventive measure or just little misfires etc?
    Hi sparker... did you do yours when you did the swirl manifolds?
    I saw the tool used in service guide is just a deep socket with universal joint and extension bar is that what you used?
    Mine is purely preventative. I always let the glow light go out before cranking and she always starts after two or three turns and i dont get any spluttering. Occasionally the Mrs doesnt do this and the car cranks a few more times before biting but is otherwise ok.
    I made my mind up to order them as i read that article that Cwizard posted a few days ago about glow plug bits going stray in the engine. I have no record in the file of mine being changed and i dont believe it is mentioned in routine maintenance therefore im sure previous owner wont have done them. BERU recommend changing them every 70,000 miles or so. Im on 107,000!
    Ive got six shiny injectors sat downstairs and a service looming, i thought for £60 delivered why not just get the whole lot done. BERU website is pretty good, it matched the ECP product code to my car manufacture period exactly. Although i am going to stick my head under the bonnet and look for the red seal at some point.
  2. Re: Which Glow Plugs for 3.0TDI (BMK)
    #22
    Mar 2008
    Herts
    Quote Originally Posted by sparker View Post
    Replace the new ones to correct toque again do not over tighten them. I'm sure there is some help on Beru website about torques for these.
    BERU recommend 15Nm i think, but its all on their website so good to check.
    1 1 0
  3. Re: Which Glow Plugs for 3.0TDI (BMK)
    #23
    Sep 2011
    Lurking over a keyboard ...
    That link I've posted suggests 17nm on metal ones... even using torque wrench there is error margin on their calibration so anything in the region of 15 to 17 nm then going to be ok..
    May then have do at some point then, mines at 80k... it may help with my issue and I'll just leave it at that ...
    Cheers for info Fieldy ...
    Do the new ones have red seal on top as well? ECP website image show them like that...
  4. Re: Which Glow Plugs for 3.0TDI (BMK)
    #24
    Mar 2008
    Herts
    Will let you know when they arrive.
    Out of interest as have been searching all day for the answer, where are the glow plugs?
  5. Re: Which Glow Plugs for 3.0TDI (BMK)
    #25
    Sep 2011
    View where the red dots are on below image...
    You will the recognise the rest of them... remove the elec.connection which look similar to a HT lead on a spark plug...
  6. Re: Which Glow Plugs for 3.0TDI (BMK)
    #26
    May 2012
    essex
    I'll be replacing mine now I've read this thread due to there cold starting performance and also when I fit my new turbo and stuff I want the best ignition I can get
    2007 3.0 tdi le mans : Hybrid turbo decat : miltek etc : 330-350 bhp : 450-500lbsft
    Visibility pack. Adaptive xenon, Privacy glass. Bose surround. Dvd nav. Comms pack, led plate lights.
    Miltek, custom map,hybrid turbo, decat improved airflow to intercoolers.
  7. Re: Which Glow Plugs for 3.0TDI (BMK)
    #27
    Nov 2012
    coalville leicestershire
    Just replaced mine with beru glow plugs from Eurocarparts BMK engine had metal red ring plugs.
    Well I've done 5 of them No. 3 did not want to move so I'll give it a couple of weeks with the Plusgas
    1 1 0
  8. Re: Which Glow Plugs for 3.0TDI (BMK)
    #28
    May 2012
    essex
    Ordered from ecp, will be fitting next weekend assuming delivered in time.
  9. Re: Which Glow Plugs for 3.0TDI (BMK)
    #29
    Nov 2010
    Watford
    On mine 3.0tdi ASB. Old glow plug (original) has red ring, and this on it; 266 020 BED. VW-A6 059963319 (then a letter i think but it is not clear)
    New glow plug has red ring and this on it; 0100 266 040 4.4V.
    They look identical apart from text.
    Audi Allroad 3.0tdi. Tiptronic. 12/12/2006. Full Phantom Black, 19" alloys, MMI high, Navigation, Phone prep, Heated sports seats with memory, Parking advanced with rear camera, Sunroof, Rear blinds.
  10. Re: Which Glow Plugs for 3.0TDI (BMK)
    #30
    Jun 2006
    UK, Mids
    I ordered NGK from ebay in the end for £63.
    Y-609AS 4.4V
    ECP lists 12v BERU 438440055 plugs when I put my reg. no. in.
    As they don't give the actual BERU part number such as GE115 I couldn't cross reference them to see if was just a webpage error. The bloke in the local branch was a brain dead as usual.
    There are 3 types (part numbers) of BERU metal plug.
    They gradually got longer tips between the tip and shoulder, the longer ones are the latest, but they all work and are suitable, so don't worry too much if some sellers list different ones.
    Audi A8 - 2015 - 3.0TDI
    2 0 0
  1. Question When do you change glow plugs in a 2.0TDI ?
    By nowa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-02-2012, 10:48 AM
  2. Replies: 6
    Last Post: 08-02-2011, 03:28 PM
  3. Glow Plugs
    By dawndriver in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-10-2010, 02:43 PM
  4. Glow plugs
    By telboblock in forum New Member Introductions
    Last Post: 05-05-2010, 09:02 AM
  5. Glow plugs, which ones?!
    By siman05 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-01-2010, 02:17 PM
