Thread: Which Glow Plugs for 3.0TDI (BMK)
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 75
  1. Which Glow Plugs for 3.0TDI (BMK)
    Jun 2012
    UK, UAE
    Hello folks,
    I know there are two types of glow plugs (ceramic and metal), does anyone know which ones are the correct type for the 3.0TDI (BMK) engine? I looked on ETKA and couldn't find a definitive answer.
    Thanks!
  2. Re: Which Glow Plugs for 3.0TDI (BMK)
    Sep 2011
    Lurking over a keyboard ...
    Only info I can supply is ...
    A - Ceramic glow plugs are colour-coded with a “white seal”
    B - Metal glow plugs are colour-coded with a “red seal”
    Other info:
    Mixed installation of ceramic glow plugs and metal glow plugs on the same engine is not permissible.
    The software of the engine control unit is specifically adapted to either the ceramic or the metal glow plugs, so it is important to install the correct type.
    As you got VCDS if you check adaptation in module [1] does balloon appear telling codes etc...
    I wouldn't adjust anything only look maybe post screenie..
    I can't find info on this and can't check on my car at mo..
    But PM to A8 Tech may reveal VW AUDI Forum - VWAF
  3. Re: Which Glow Plugs for 3.0TDI (BMK)
    Jun 2012
    UK, UAE
    Yeah I saw that too, I was wondering if there was a way of telling which ones I need without removing one. Last time I had glow plugs replaced by Audi, one broke off which I hear is a common issue that they have when removing them. Unfortunately I can't find the invoice to see if it had part numbers or details of whether they were metal or ceramic ones. Coincidentally, its the same glow plugs that I think now need replacing...
  4. Re: Which Glow Plugs for 3.0TDI (BMK)
    Sep 2011
    As not mechanic excuse my terminology...
    The coloured seal is above the nut/section of glow plug the socket would go on so should be visible before removal...
    My missus gone out with car can't look at mo, if get chance will try to view on mine for my info...
    Quote Originally Posted by six_or_out View Post
    ...Last time I had glow plugs replaced by Audi...
    If you phone them they may be able to tell you...
  5. Re: Which Glow Plugs for 3.0TDI (BMK)
    Nov 2010
    Watford
    I have replaced a couple of glow plugs on my 3.0tdi 2006 171KW (if that is BMK, not sure). Did some research first.
    The glow plugs in this engine are manufactured for Audi by BERU. Don't use any other make they will not last!
    Beru part type GE 115. Part no.0 100 266 040. They should be available from Euro car parts under part no. 438 44 0015 I believe (much cheaper than Audi ringed ones).
    Have a look on Buru site for the information needed.
    These have white steel nut and thread.
    I'm sure you will find them, if not let me know.
    Audi Allroad 3.0tdi. Tiptronic. 12/12/2006. Full Phantom Black, 19" alloys, MMI high, Navigation, Phone prep, Heated sports seats with memory, Parking advanced with rear camera, Sunroof, Rear blinds.
  6. Re: Which Glow Plugs for 3.0TDI (BMK)
    Apr 2012
    Aylesbury, Bucks
    Following on from Sparkers thread, on the Eurocarparts site you can enter your reg into it, then select the components you're looking for - engine > glow plugs > view product. There you will see the VIN number "from" line to cross-check against your car.
    Must be one of the cheapest Audi parts available!!!
  7. Re: Which Glow Plugs for 3.0TDI (BMK)
    Oct 2012
    Berkshire
    10 Post(s)
    Be careful with Eurocarparts cross- check ! Iv had some mixed results with Brake Pads, Disks & filters. All changed on the desk but it is a hassle if its not right first time. Best to rock up with the old part if you can or get one of each of the new options and take the ones you don't use back.
  8. Re: Which Glow Plugs for 3.0TDI (BMK)
    Jun 2006
    UK, Mids
    Thanks for the warning. I just ordered some from ECP, great price with the 25% off code.
    Audi A8 - 2015 - 3.0TDI
  9. Re: Which Glow Plugs for 3.0TDI (BMK)
    Mar 2008
    Herts
    Quote Originally Posted by snapdragon View Post
    Thanks for the warning. I just ordered some from ECP, great price with the 25% off code. They specify 438440055 which is 4.4V so clearly wrong.
    Hi Snapdragon,
    Just about to order these off ECP, they specify Beru plugs (code: 438440015) @ £9.90, all the information they provide seems to be correct. Just noted your comment above about 4.4v and wondered how you got on with the ones your ordered as the info on ECP still states 4.4v?
    Many thanks
  10. Re: Which Glow Plugs for 3.0TDI (BMK)
    Nov 2010
    Watford
    Hi Fieldy,
    The part no. you have there is the same as the Beru item from ECP which I fitted to my ASB 3.0tdi. If they are the same for your engine then I can confirm they work perfectly in my car and where identical too the originals bar the Audi rings. I cross referenced these on the Beru website to check they where correct for my ASB engine. They have worked perfectly since fitting.
    2 1 0
  1. Question When do you change glow plugs in a 2.0TDI ?
    By nowa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-02-2012, 10:48 AM
  2. Replies: 6
    Last Post: 08-02-2011, 03:28 PM
  3. Glow Plugs
    By dawndriver in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-10-2010, 02:43 PM
  4. Glow plugs
    By telboblock in forum New Member Introductions
    Last Post: 05-05-2010, 09:02 AM
  5. Glow plugs, which ones?!
    By siman05 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-01-2010, 02:17 PM
