Thread: gearbox compability from audi 80 to audi 100
  1. gearbox compability from audi 80 to audi 100
    Jun 2012
    sweden
    hi, I got a audi 80 1.8 -90 that have a bad manual gearbox so I bought a manual gearbox of my friend, but it turned out to be from a audi 100 2.0 -90. When I was about to change it I saw that the inner driving joint wasnīt the same. Can I take the inner driving joint from the audi 100 so it will fit? Is there something more that isnīt the same?
    greatful for all help I can get.
  2. Re: gearbox compability from audi 80 to audi 100
    Gwent
    was the 100 5 cylinder? Not sure if there is an issue with starter motor, going from 4 cyl type to 5 cyl type?
    I think the drive shaft flanges will swap over ok.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: gearbox compability from audi 80 to audi 100
    Jun 2012
    sweden
    Itīs a 4 cyl type because the gearbox came from a audi 100 2.0.
  4. Re: gearbox compability from audi 80 to audi 100
    Gwent
    I was concerned that the 100 came with a 5 cyl 1994 cc engine in 1990, The 4 cyl 1984cc engine arrived in 1992 as far as I can tell. If your spare gearbox is from a 4 cyl you should have no problems?
  1. Fitting an Audi A6 Sub Woofer to my Audi 100????
    By Schmall fella in forum In Car Entertainment
    Last Post: 28-09-2010, 03:19 PM
  2. Fitting an Audi A6 Sub Woofer to my Audi 100????
    By Schmall fella in forum 100 - 200 - Turbo - 100 S4
    Last Post: 28-09-2010, 03:18 PM
  3. Replies: 0
    Last Post: 04-08-2010, 03:05 PM
  4. Audi 100 s4
    By s4sneil in forum 100 - 200 - Turbo - 100 S4
    Last Post: 16-12-2008, 02:14 AM
  5. no start audi 100
    By jimbcah in forum 100 - 200 - Turbo - 100 S4
    Last Post: 11-08-2007, 10:02 AM
