Thread: Is an ET43 alloy going to fit
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Is an ET43 alloy going to fit
    Feb 2010
    Cambridge
    I have an alloy fitment guide which tells me that 8J x 18 rims should have an offset between 35 and 42.
    However most of the alloys I have found have a 43 offset.
    Does anyone know if this will cause me any issues?
    A6 3.0 TDI Le Mans
  2. Re: Is an ET43 alloy going to fit
    Sep 2011
    Lurking over a keyboard ...
    Some good info in this thread...
    New Alloys offset?
  3. Re: Is an ET43 alloy going to fit
    Feb 2010
    Cambridge
    Yep saw that thread, but just wanted to check if ET43 would cause any issues since the document I have says a max ET of 42
    A6 3.0 TDI Le Mans
    Jul 2011
    Near Uxbridge
    Should be fine.....minute difference between 43 and 42......I think its measured in mm ......
    Sent from my HTC One X using Xparent Red Tapatalk 2
    Consultation en ligne viagrasansordonnancefr.com immunite des francais
  5. Re: Is an ET43 alloy going to fit
    Sep 2011
    In the linked thread the calculator you input your current alloy eg 7J = 7in width your current eg offset 42 = 42mm
    Then your input your proposed change eg 7J = 7 in 43 = 43mm
    Attachment 17012
    As you can see by changing offset by 1 not make much difference....
    Alloy width has a greater effect...
    Attachment 17013
    So now alloy is 7mm closer to your strut (suspension), whilst coming out by 5mm as well, compared to example
    So another question is what is your current alloy width?
    Just had a quick scan I think the alloys that A6_Chris has are 19in 8.5j ET48...
    Mine are 17in 8j ET48...
    As yours 2.7TDI (shares a lot parts with 3.0), minus Quattro that me and Chris got I would be very surprised if if max is ET42...
    What doc you got?? you referencing...
  6. Re: Is an ET43 alloy going to fit
    Feb 2010
    Cambridge
    I got a PDF, from somewhere, which list loads of cars with alloy fitments. I currently have 16's but no idea what width and offset they are.
    When I get the car back from the garage I will check
    A6 3.0 TDI Le Mans
  7. Re: Is an ET43 alloy going to fit
    Sep 2011
    Only my opinion mate... I got 17in 8J with 245/45/17 tyres... cheaper than 19's for rubber, but with the width for grip etc plus as have larger sidewall less chance of kerbing by my partner... another one is people with 19s keep posting about road noise from tyres again as they have smaller sidewall...
    IMO like you considering 18s for mine when get other stuff done... that probably sweet spot but again I would go for an alloy which you can put a wider tyre get some more grip for that 2.7 TDi = more when cornering etc..
  8. Re: Is an ET43 alloy going to fit
    Oct 2010
    leeds
    Sorry to hijack the thread but I am looking at buying some 18" wheels for my A6. Standards are 225 50 17 and from what the seller told me the 18" wheels have 215 45 18 tyres. After checking on the websites I found that with the 18" wheels and tyres my overall diameter of the tyre is 6mm lower than the standards which is less than the original by 0.91%. Now I am not sure whether I should go for them or not. Dont think theres any problem with diameter but would there be issues with 215 wide tyres?
    Raj
    Jul 2011
    Near Uxbridge
    You need 245 40 18.....that's the standard size on my factory fitted alloys. I use 225 50 17 as my winter alloys.....also Audi recommended size.
    Neil
  10. Re: Is an ET43 alloy going to fit
    Oct 2010
    leeds
    I gotta check with him on the width cos he was throwing the wheels along with 2 almost new 215 P zeros but they wont be of any use to me. Wheels are 42 offset from what I remember and they 114x5 stud diameter. Arent A6 17" standard wheel 112x5 stud diameter?
    Raj
  1. Would A5 ET28 alloy fit A6 C6
    By Gio123 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-03-2012, 01:29 AM
  2. Alloy wheels - what do they fit?
    By Harrythecat in forum Wheels and Tyres
    Last Post: 09-03-2011, 03:42 PM
  3. Question Changing to bigger Alloy Will they fit?
    By ghost in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2010, 11:28 AM
  4. what size tyre to fit alloy?
    By Aaftab in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-09-2009, 12:06 PM
  5. S3 alloy wheels..will they fit my A3
    By AwdiBoy in forum Audi A3 - Archive Topics
    Last Post: 08-05-2007, 03:08 PM
