Thread: slightly noisy interior fan
  1. slightly noisy interior fan
    May 2012
    Nr Barmouth Gwynedd
    Hi I have noticed that when my air con/heater fan is set to about half way it sounds like the bearing is on the way out, if i speed or slow the fan down the noise stops. Any ideas? Is it a new heater fan? and if so where from online? Would it be worth asking a breakers for one? And also how much of a job is it to replace? Sorry I havent got a workshop manual yet.
    Thanks.
    2002(52) AUDI ALLROAD QUATTRO 2.5 V6 TDI AUTO TIPTRONIC
    1996(N) 300 series Discovery XS 3.9 V8 efi, manual, single point LPG converted
  2. Re: slightly noisy interior fan
    Apr 2009
    Epsom Downs
    Problem with a breaker is that it's likely to be the same or worse, and chances are you won't know till it's fitted...
    The proper "green" fix is to replace the bearings on the fan motor, obviously requiring getting the fan motor out to see if it's possible.
    If you've not found a manual yet, it's probably worth looking on ebay for a DVD version, but the Bently manual is not the most detailed, so try a different one.
    It has to be said that there are loads of illegal copies of the Official VAG Workshop Manual on Ebay, so bear this in mind when bidding....
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  3. Re: slightly noisy interior fan
    Mar 2012
    United Kingdom
    Hello, mine can be noisy too, blamed it on water ingress, lift the plenum chamber cover panel (battery access panel and its mount) and take out the pollen filter, its worth checking for water ingress around its base seal and debris build up around the bonnet hinges. Mine is noisiest on recirculation and when its turned off it doesn't always disengage from that, I have to turn down the fan speed to the heater / climate off position and back on again. Worth trying both and check for debris that may have took the fan out of balance too.
    2001 A6 Avant - ASN Engine Code - 3.0 Quattro - 1,000 miles per week
    1 1 0
  4. Re: slightly noisy interior fan
    Jul 2014
    Sydney Australia
    Thank you for the detailed information, Unfortunately mine is still making a squealing bearing noise at low RPM. Hi RPM approx. 50%the noise is gone.
    Does anybody have a diagram of where the heater fan motors, I have the Factory w/shop manual already , but not really clear.
    Regards
    SGM Charles
    Quote Originally Posted by JimTraining View Post
  1. Noisy Fan Vents?
    By Drifty in forum Passat CC
    Last Post: 18-04-2011, 05:25 PM
  2. noisy fan when it kicks in
    By earwax31 in forum Polo - Derby - Lupo - Fox
    Last Post: 05-04-2011, 11:48 PM
  3. Noisy cabin ac fan
    By gazza57 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-10-2010, 10:13 AM
  4. Noisy AC Fan
    Last Post: 13-10-2010, 12:22 PM
  5. Noisy fan
    By SteveX in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-04-2009, 08:20 AM
