Thread: speakers
  1. speakers
    Dec 2007
    wigan
    can someone tell me the best speaker upgrade for the b5.5 passat estate... i wish to keep the genuine tweeters as well...??
    i have a 1 or 2 rattling / distorting one rear and one front
    or just buy replacements from vw..
    Passat Tdi 130 Sport
    Audi RS4 alloys polished alloy fronts
    no mod's
  2. Re: speakers
    Jul 2010
    Brighton
    these are what i fitted recently http://www.ebay.co.uk/itm/VW-Passat-...item1e61888caa they work brilliantly and are a better sound than the originals they also do the rears to match too, i just fitted by drilling out the old rivets and refitted these in the same holes with rivets took me around 45 mins to fit them
    Nov 2011
    Essex
    There is only a couple of things to remember when buying speakers.
    1. Impedence. On the back of the original speaker hopefully there should be 8 or 4 ohms, after the number there will be an Omega symbol if ohms isnt written. If you put the wrong impedence speaker in ypu could blow tge outputs on the amp of the.heatunit.
    2. Power. This will be written as sething like 25 watts, buy the wattage or above, if its lower when you.turn it up the speaker will blow
    And of course the size, make sure it fits the hole, diameter and depth clearence in tge doors.
    Thw fixing holes may be different on the new speaker but you can drill new fixing holes
    If you know the power of the headunit for example 200W that would mean if you had 4 speakers 50W each speaker
    Sent from my GT-P1000 using Tapatalk 2
    Furion
    Gone: Audi A6 Avant Le Mans 3.0 TDI 6 Speed Tiptronic
    Gone: VW Touareg Se Sport 3.2 V6
    Gone: BMW 325i M Sport
    Gone: Merc E240
  4. Re: speakers
    Dec 2007
    wigan
    Quote Originally Posted by Toonmania View Post
    did you use the original tweeters or disconnect them...??
    no mod's
  5. Re: speakers
    Jul 2010
    Brighton
    i've just left them in and seem fine just changed the speakers front & back
  1. New Speakers
    By steeevo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-04-2009, 09:55 PM
  2. Question Speakers
    By andy23961 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-02-2009, 11:27 AM
  3. Which Speakers...
    By andy_c_v in forum In Car Entertainment
    Last Post: 27-10-2008, 08:19 PM
  4. Question 10 speakers - but where?
    By tomjj in forum Golf MK5 - 2004 - 2009
    Last Post: 18-09-2008, 12:51 PM
  5. speakers
    By herb in forum Eos
    Last Post: 13-03-2008, 08:24 PM
