Thread: CV Joint or Wheel Bearing
Results 1 to 10 of 12
  1. CV Joint or Wheel Bearing
    Jun 2009
    Telford UK
    Hi All
    Since i have had a CV boot replaced i have noticed a slight metal on metal sound coming from OS front
    It only happens when slightly turning right and when everything warmed up ie 20 min drive then can be heard turning right at slow speed
    Checked the brake disk back plate clearance and all is good
    Any thoughts
  2. Re: CV Joint or Wheel Bearing
    Jun 2007
    Gwent
    Check the hub centre bolt is tight?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: CV Joint or Wheel Bearing
    Jul 2010
    Brighton
    it sounds to be like a bit of disc warp or something, it sounds like something that is being affected by heat so the warmer it gets the noisier it becomes, generally a wheel bearing will give you a horrible droning noise i would take both front wheels off and visually check the discs and pads could even be you have a sticky brake piston which isn't retracting fully best to have a good look around and at the same time check you nuts!!!
  4. Re: CV Joint or Wheel Bearing
    Jun 2009
    Telford UK
    Hi All
    Good point about centre bolt ... i dont have any play in the 12 and 6 and 3 and 9 o clock position but worth a look....
    Brake disks and pads are all new... and sh*t hot stopping.. last pads fitted by my local indi were crap must of been the cheapest parts around
    Going to check that centre bolt but do not have the tool for that yet..
    I Know that bolt has been un done 4 or 5 times in the past few years so wondering if it has stretched to much....
    The noise is only there when turning right slightly .. straight is fine and full lock is fine just slightly of centre then metal metal noise....
  5. Re: CV Joint or Wheel Bearing
    Jul 2010
    Brighton
    from your last description i'm wondering if it's the cv joint making the noise it sounds a bit like it might have gone dry
  6. Re: CV Joint or Wheel Bearing
    Jun 2009
    Telford UK
    Hi
    Do you know if the centre hub bolt is 17mm hex or 19mm
  7. Re: CV Joint or Wheel Bearing
    Jul 2010
    Brighton
    pretty sure mine are 17mm hex, i had trouble finding something to fit so bought a 17mm hex sump key with a 14mm hex the other end so i can just undo with air gun or a breaker bar and 14mm impact socket
  8. Re: CV Joint or Wheel Bearing
    Feb 2010
    luton uk
    just done my cv this weekend and the bolt was a 17mm hex on the hub and the bolts on the gearbox end are 8mm xzn bolts( Halfords | Halfords Professional 7 Piece Spline Bit Socket set 1/2" also need a bloody big bar and plenty of spinach too ,regular thread direction too . took me 1.5 hrs to replace mine .
  9. Re: CV Joint or Wheel Bearing
    Jun 2009
    Telford UK
    Hi All
    If it is just a dry CV joint can i just cut the tyrap off the large end of the cv boot and just re pack with grease then re tyrap ??
    Saves stripping it all down..
  10. Re: CV Joint or Wheel Bearing
    Jul 2010
    Brighton
    Yes you can, but you have to ask yourself why it's dry and where has all the old grease gone?? personally for the price of a joint as soon as they go dry or start knocking i just change them out but that's just me
  1. CV JOINT or Wheel Bearings
    By Walesgbn in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 29-02-2012, 11:42 AM
  2. CV Joint or Wheel Bearing noise?
    By Amsel in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-02-2012, 05:45 PM
  3. Front Wheel Bearing or CV Joint????
    By dazza23 in forum Golf MK5 - 2004 - 2009
    Last Post: 24-12-2009, 11:39 AM
  4. How To Change wheel bearing rear wheel
    By thecableguy12 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-11-2009, 01:56 PM
  5. Question Wheel bearing noise not a Wheel bearing
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2009, 10:31 PM
