Thread: Dead turbo
Results 1 to 8 of 8
  1. Dead turbo
    Jun 2012
    tamworth
    Hi all, new to this forum and need a bit of your expert advice. I've got a 2003 1.9tdi sallon and while driving down the motorway, suddenly started blowing out loads of smoke from the exhaust but no power loss. Pulled over onto shoulder then the engine started revving its knackers off. Switched it off then called AA. Guy said that the turbo has blown and drawing oil from the sump which caused the revving. Other than just changing the turbo which is pretty straight forward, what other dammage could have been done ?
    Cheers Jez
  2. Re: Dead turbo
    Pembrokeshire
    22 Post(s)
    welcome to the forum. it depends how high it revved really and for how long. luckily you have an anti stutter valve will kills the air supply in these situations. not all cars do and they keep running with the ignition off, until they use all the oil and seize, or blow up.
    you could disconnect the pipe from the turbo to manifold so the turbo's not in use and check it idles fine with no knocking or lumpiness. other than that, all you can do is stick a new turbo on and pray. dont forget to remove the oil supply pipe and either replace it or thoroughly clean it inside, as new turbos hate a restricted supply or bits of carbon going through them.
  3. Re: Dead turbo
    Jun 2012
    tamworth
    Thanks for the quick reply. Will try what you've suggested later and let you know how I get on.
  4. Re: Dead turbo
    Pembrokeshire
    22 Post(s)
    place a bucket near the boost pipe as it may chuck a load of oil out, and you will need to remove all the boost pipes and intercooler to clean all the oil out. the exhaust will be full as well, so really should be removed and drained, as it will smoke like a big smokey thing for 10 miles or so, which is a recipe for a pull from mr plod.
  5. Re: Dead turbo
    Jun 2012
    tamworth
    Hi, disconected all of the pipes, removed the inlet manifold to get to the turbo. The pipe from the intercooler was full of oil so all of that has to come out.The only problem I'm having is undoing the oil feed at the turbo end. Turning the nut but the pipe is turning with it and starting to kink. Any hints or tricks ?
    Jez
  6. Re: Dead turbo
    Pembrokeshire
    22 Post(s)
    cut the pipe and get a new one. it is recommended to replace it at the same time as a turbo anyway, and is in the warranty stipulations for a lot of turbo suppliers. they can gunge/carbon up inside where they get hot near the turbo, and if any of that gets into the new turbo it will cost you a lot of money.
  7. Re: Dead turbo
    london/ UK
    Jez, how long did the engine rev on itself for ? They suck oil inside the pistons and the rods get bent because of hydrolocking- oil cannot be compressed much hence the rods bending as they are the weakest link ! Hope you did not cause much damage otherwise it's head and oil sump off to replace the bent rods !
  8. Re: Dead turbo
    Jun 2012
    tamworth
    Hi it only revved for maybe 10 seconds then it was turned off so hopefully no hydro (killed a defender with a faulty snorkel in a river before lol)Just going to clean it all out, fit new turbo, refil and hope for the best. Thanks for all the advice guys.
  1. Blown turbo. Is it possible to replace a k03 turbo with k04 turbo
    By A4slineavant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2012, 07:45 AM
  2. Passat B6 Dead Turbo
    By tickorama in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-12-2011, 02:41 AM
  3. 2001 a6 1.9tdi turbo dead - damage to engine?
    By needmorstuff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-07-2010, 10:53 AM
  4. dead turbo no boost after 2 months standing?
    By minty0_10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2008, 08:24 AM
  5. I'm not dead
    By Marc97 in forum Chat - Completely Off Topic
    Last Post: 31-12-2006, 03:00 AM
