Thread: Boost Help! Code: 379
  1. Boost Help! Code: 379
    Jan 2012
    Well the cars got a lot worse (https://www.vwaudiforum.co.uk/forum/s...-Photo-request
    and I took it into Audi who said they'll look at it Next Tuesday just to do diagnosis - £144!
    So I ended up calling around local mechanics and a chap popped down and used a Bosch Code reader and the following came up:
    379
    Boost Pressure Control - Control Deviation Negative?
    I'm trying to fault find and have lightly sprayed liquid over the lines to to the turbo to see if there any leaks and cant find anything.
    The weird thing is if I start the car up and start driving its fine....20mins into a journey and the car falls into a sort of 'limp mode' where I get no boost from the Turbo...
    considering I'll have to wait for Audi next week anyway....does anyone have any suggestions to locate the cause?
    Thanks in advance.
  2. Re: Boost Help! Code: 379
    Dec 2009
    southampton uk
    How do they estimate £144?It may be worth having the best advice cos it may be tricky to find.Sounds similar to what my son had on his S3 when diagnostics failed to locate a faulty throttle body
  3. Re: Boost Help! Code: 379
    Jan 2012
    Ended up taking it TJB in Alperton where Tom was able to diagnose it as the EGR. Gave it a good clean and removed all the carbon build up so far so good, no limp mode yet. And fells better when putting foot down. :-)
    I'll post an update after 300+ miles.
  4. Re: Boost Help! Code: 379
    Jan 2012
    So far so good...hasn't gone in limp mode since
  1. Replies: 12
    Last Post: 24-05-2017, 04:10 AM
  2. Fault code 379 on A4 2.0 TDI B7
    By Andy_Pigott@msn in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-11-2011, 07:04 PM
  3. Intermitant Boost Fault (Code 17965)
    By dazrick68 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-11-2009, 08:51 PM
  4. Please Help error code 00550 boost issue
    By 4udi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-06-2008, 02:35 PM
  5. Over Boost Code p0234
    By whiteturbo in forum Archive posts
    Last Post: 24-01-2008, 04:13 AM
