Thread: Audi A4 Avant Rear Wiper Blade and Arm
  1. Audi A4 Avant Rear Wiper Blade and Arm
    Jun 2012
    Derby U.K.
    Hi, The rear wiper blade over runs and now starts/finishes its wiper arc on the boot paint work not the rear glass screen.
    Is this simple to rectify? Can i upgrade to a later style aero arm assembly?
    How do I remove the arm? Please help
    Vehicle spec is AUDI A4 2005 Avant S-Line
  2. Re: Audi A4 Avant Rear Wiper Blade and Arm
    Oct 2010
    Harrogate, n. yorks
    Click off the outer cover.
    Pull off the washer jet assembly - this might damage the seal so be prepared to go buy another one if necessary. Cheap.
    Undo the nut.
    Pull the arm off - I've read that some arms pull off easily but mine was a pig and well stuck. I ended up destroying it with an cutting disc to remove it. Try heating the whole area with a hair dryer or hot air blower.
    Reposition the arm and re-assemble.
    Deaks
  3. Re: Audi A4 Avant Rear Wiper Blade and Arm
    Jun 2012
    Derby U.K.
    Quote Originally Posted by Deakin View Post
    Undo the nut.
    Deaks
    Thanks for that, yes mine is stuck on, will try some WD40 first. Is the spindle splined or just round, can I re-position anywhere, or only a number of positions?
  4. Re: Audi A4 Avant Rear Wiper Blade and Arm
    Dec 2011
    perranporth, cornwall
    Its on splines but they are small so can reposition anywhere. If it's tight you may want to try using a puller before condeming the arm by cutting it.
  5. Re: Audi A4 Avant Rear Wiper Blade and Arm
    Jun 2012
    Derby U.K.
    Quote Originally Posted by lukeybaby View Post
    Thanks, can I upgrade to the later aero type arm/wiper as fitted to the later B8 versions?
  6. Re: Audi A4 Avant Rear Wiper Blade and Arm
    Dec 2011
    Not sure... would be nice to have though. If you find out let us know.
  7. Re: Audi A4 Avant Rear Wiper Blade and Arm
    Dec 2011
    I been searching the web and believe that the B8 rear wipers will fit but the blade needs cutting down, or some people have been fitting Q5 rear arms which are about half an inch smaller on the lower arch.
    These are the part no. for the Q5 that i found on the web
    Wiper Arm: 8R0-955-407-1P9
    Wiper Blade: 8R0-955-42
    Cap:8K9-955-205
  1. How to remove the rear wiper arm from a 57 plate avant
    By oldsurfdude5670 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-03-2010, 08:23 PM
  2. Question A4 Avant rear wiper motor (and arm)
    By maclemming in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-02-2010, 04:38 PM
  3. Audi Avant Rear Wiper Arm Removal - help!
    By Rich3153 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-07-2009, 08:39 PM
  4. A4 Avant Rear Wiper Arm & Blade
    By iawwuk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-11-2007, 12:27 PM
  5. A4 Wiper Blade Arm - Blade Clip
    By lbaters in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-12-2006, 01:16 AM
