Thread: Power steering failure
  1. Power steering failure
    Dec 2010
    Chelmsford, United Kingdom
    Hi, I have just limped home having lost the power steering on my 1998 VW Passat TDI.
    I started to notice strange noises on Saturday which have deteriorated into grinding, shreeching, and whirring - worse when turning - to the extent that people have looked at the car. Whilst out on a errand this morning, I have lost all power steering, the power steering fluid has leaked out from under the car, and it has sprayed under the bonnet from the filler cap of the power steering reservoir. There also appears to be a small amount of metal shavings laying in the cover that protects the underside of the engine. The performance of the engine has not been affected. I will limp to my garage on Wednesday morning, but would be grateful if anyone could suggest what has happened.
  2. Re: Power steering failure
    131 Post(s)
    1973 Post(s)
    Sounds like your alternator one way clutch failed which destroyed the tensioner so the belt flew off, you must fit a new pulley with a new tensioner or the tensioner will fail again and the supplier will refuse warranty. The fluid can spray out when operating the steering with no pump.
  3. Re: Power steering failure
    Dec 2010
    Thank you Crasher - roll on Wednesday.
  1. Possible Power Steering Pump Failure ?
    By alanred in forum Polo - Derby - Lupo - Fox
    Last Post: 28-07-2010, 11:59 AM
  2. Power Steering failure
    By jim77 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-02-2010, 05:17 PM
  3. Power Steering failure
    By chuileog in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-03-2009, 09:08 AM
  4. intermittent power steering failure
    By snoopydo in forum The Commercial Range
    Last Post: 03-03-2009, 12:40 AM
  5. Please Help Power Steering failure
    By jimat57 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-07-2008, 09:34 PM
