Thread: Poor Performance
Results 1 to 10 of 10
  1. Poor Performance
    Jun 2009
    Isle Of Wight
    I have a 2001 B6 1.8TQ with 117000 miles on the clock.
    Recently I have been getting intermittant Turbo boost now there is nothing at all. The Turbo still spins up and makes all the right noises but does nothing to performance. There are no fault codes logged, no oil in the exhaust and everything else seems normal. I have checked for leaking pipes but there is nothing obvious and certainly no noise associated with a split pipe. I am starting to think its the dump valve.
    Any thoughts.
  2. Re: Poor Performance
    Jun 2006
    Cardiff
    MAF & DV would be my first things to check.
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
  3. Re: Poor Performance
    Jun 2009
    Isle Of Wight
    I did consider the MAF but the last time this failed (another car) it was associated with irractic fuel comsumtion. I will disconnect it and see what happens.
  4. Re: Poor Performance
    Jun 2009
    Isle Of Wight
    Fuel consumption has remained about the same pre and post lack of turbo boost if that makes any differance.
  5. Re: Poor Performance
    Jan 2009
    Birmingham
    36 Post(s)
    Could it be the map sensor?
  6. Re: Poor Performance
    May 2012
    leominster
    Have you had the vehicle scanned for fault codes, this is the best way to save money and not fit parts that are not needed, Yes it is not the answer to everything but it it narrows down the options, A good VAG speacialist will help you out, my theory is the N75 this controls the turbo check for leaking vacum hoses. hope this helps.
  7. Re: Poor Performance
    Jun 2006
    Cardiff
    Quote Originally Posted by arman123 View Post
    Could be. You can clean it with Isopropal.
  1. Please Help Poor performance
    By davo1300 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-05-2009, 02:04 PM
  2. Please Help Poor performance
    By davebrown in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-07-2008, 06:03 PM
  3. poor performance
    By vwturbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-02-2008, 10:30 PM
  4. Poor Performance
    By Foxcub in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-02-2008, 06:34 PM
  5. poor performance
    By hywelg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2008, 06:14 PM
