Thread: 2008 3:0TDI Engine V Facelift 3:0TDI Engine
  1. 2008 3:0TDI Engine V Facelift 3:0TDI Engine
    Nov 2011
    Essex
    Is the facelift 09/10 3:0tdi engine just a remapped engine of the pre facelift?
    The facelift has better fuel economy. Less emmisions and so on and i was woundering if remapping my 2008 could improve fuel economy and emmisionz without losing performance?
    Ive been tempted.to remap for performance but obviousley economy has a direct relationship withe ones right foot.
    Sent from my GT-P1000 using Tapatalk 2
    Furion
    Gone: Audi A6 Avant Le Mans 3.0 TDI 6 Speed Tiptronic
    Gone: VW Touareg Se Sport 3.2 V6
    Gone: BMW 325i M Sport
    Gone: Merc E240
  2. Re: 2008 3:0TDI Engine V Facelift 3:0TDI Engine
    Sep 2011
    Lurking over a keyboard ...
    ASFAIK know mate only difference between (apart from cosmetic/mmi) two would be superseded parts/newer software in modules...
    Mine has no DPF, this was a) confirmed by dealer b) popping PR codes from data into this handy tool http://prsearch.planetvag.com/
    PR Code: 7GN = Emission standard EU4 DPF preparation
    I've seen Audi have a retro-fit kit of DPF so I am assuming what above mean is that is ECU and car is prepped to have, but does not have it, I could be wrong... did not investigate much as I wouldn't want a DPF (clogging,etc)
    Do not know when DPF on 3.0 come in/have either...
    Your engine code maybe ??? mine BMK...
    225PS (165 kW; 222 hp) > 233PS (171 kW; 230 hp) > PS240 (177 kW; 237 hp)
    Nov 2011
    Essex
    My engine is a 233bhp.
    I would prefer not to have a dpf to for the same reason, although my maye has one on his saab93 which hasnt given him any real issues
    Furion
    Gone: Merc E240
    Nov 2011
    Essex
    Checked codes. It appears to have dpf prep. So dows this mean a dpf can be added easily ?
    PRCode: 0GZ = Emission standard EU3 diesel with EOBD
    PRCode: 0JK = Weight category front axle weight range 10
    PRCode: 0YK = Weight range 10 installation control only no requirement forecast
    PRCode: 1BV = Sports suspension/shock aobsorption
    PRCode: 1KW = Disc brakes rear
    PRCode: 1N3 = Speed-related variable steering assist (Servotronic)
    PRCode: 1SA = Without additional engine guard
    PRCode: 1X1 = Four wheel drivea
    PRCode: 1ZL = Disc brakes front
    PRCode: 2FQ = Leather trimmed multi-function sports steering wheel w/ Tiptronic
    PRCode: 2K7 = Reinforced bumpers
    PRCode: 3FA = Without roof insert (standard roof)
    PRCode: 3L3 = Manual height adjustment for front seats
    PRCode: 3NZ = Rear seat bench unsplit backrest split folding
    PRCode: 3Y0 = Without roll-up sun screen
    PRCode: 4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
    PRCode: 4K2 = Radio remote controlled central locking SZV
    PRCode: 4KF = Side windows in heat-insulating glass from B-pillar and rear window dark tinted
    PRCode: 4R4 = Power windows with comfort operation andcircuit breaker
    PRCode: 4UF = Driver's and front passenger air bag with front passenger air bag deactivation
    PRCode: 4X3 = Side air bag front with curtain air bag
    PRCode: 5D7 = Carrier frequency 868 MHz without panic button
    PRCode: 5SJ = Left exterior mirror: convex
    PRCode: 5TG = Decorative aluminum inserts dulling
    PRCode: 6TS = Right exterior mirror: aspherical large viewing field
    PRCode: 6XD = Exterior mirrors: electrically adjustable/heated
    PRCode: 7GN = Emission standard EU4 DPF preparation
    PRCode: 7K0 = Without tire pressure warning light
    PRCode: 7Q2 = Navigation system with color screen
    PRCode: 7X1 = Park distance control
    PRCode: 8EC = Bi-functional headlight with gas discharge lamp for driving on the left
    PRCode: 8GV = Alternator 180 A
    PRCode: 8Q5 = Headlight-range adjustment automatic/ dynamic with dynamic bending light (AFS 1)
    PRCode: 8Z5 = Not hot country
    PRCode: 9Q4 = Multi-function display/on-board computerwith check control
    PRCode: C8K = Alloy wheels 8.5J x 19
    PRCode: D1D = 6-cyl. turbo dies. eng. 3.0 L/171 kW 24VV6 TDI common rail base engine is T41
    PRCode: E4J = S-line
    PRCode: F0A = No special purpose vehicle standard equipment
    PRCode: J0Z = Battery 520 A (110 Ah)
    PRCode: Q1D = Sports front seats
    PRCode: T41 = 6-cylinder diesel engine 3.0 L unit 059.D
    PRCode: U1B = Instrument insert with mph speedometer clock tachometer and trip odometer
    PRCode: X2B = National sales program Great Britain
    Furion
    Gone: Merc E240
  5. Re: 2008 3:0TDI Engine V Facelift 3:0TDI Engine
    Sep 2011
    Sorry for late reply...
    AFAIK I know yes there is a retro fit kit...
    Will fish out info just rebuilding PC and laptop
  6. Re: 2008 3:0TDI Engine V Facelift 3:0TDI Engine
    Sep 2008
    mostly in the garage
    why would you have a DPF if your not required to have one? it will make mpg worse!
    an engine remap will return better fuel economy when driven gently, the increased torque allows you drive in a higher gear hence the saving.
    46 Post(s)
    Quote Originally Posted by c4a5er View Post
    x2 - I'm having my fair share of clogginess with the a3 and if it wasn't for warranty it would be ripped out and a remap applied.
  1. 3.0TDi - Possible engine problem
    By jdp1962 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-05-2012, 03:42 PM
  2. Please Help A4 2.0TDI Engine Problem
    By fancy a cuppa in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-09-2010, 10:51 PM
  3. Please Help engine problems - 2.0TDI
    By brummieboy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-08-2010, 10:35 AM
  4. Reliability of 2.0TDi engine?
    By Remaster in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-01-2009, 10:54 PM
  5. Question Audi A4 2.0tdi engine
    By robinsev in forum Chat - Anything with wheels
    Last Post: 06-01-2009, 07:22 PM
