Thread: Where is the Temperature flap motor?
Results 1 to 10 of 13
  1. Where is the Temperature flap motor?
    Feb 2010
    Cambridge
    I believe this is causing me some issues with the air con randomly blowing hot air on the drivers side vent.
    Can anyone advise where it is? It doesn't seem a particularly expensive part so I'm hoping its easily accessable.
    A6 3.0 TDI Le Mans
  2. Re: Where is the Temperature flap motor?
    Feb 2010
    Cambridge
    Should have said that I am getting the car scanned to see which one it is, but since its normally the drivers side window blower thats normally the problem I assume only one motor relates to that vent
    A6 3.0 TDI Le Mans
  3. Re: Where is the Temperature flap motor?
    Sep 2011
    Lurking over a keyboard ...
    google SSP 323 , air con stuff start page 58, page 64 & 65 have info on motors/flap control
    once you have scan can try to see if can then advise on how you change,etc
    2 0 0
  4. Re: Where is the Temperature flap motor?
    Jan 2012
    nr bristol, somerset
    Quote Originally Posted by gupsterg View Post
    wow. i am liking that document! john.
  5. Re: Where is the Temperature flap motor?
    Sep 2011
    Quote Originally Posted by johnnyone View Post
    Check links in here https://www.vwaudiforum.co.uk/forum/s...250#post719250 may make you even happier
    Check this thread as well https://www.vwaudiforum.co.uk/forum/s...on-Not-Working
    Some good guidance from Einstein really got ball rolling there for everyone
  6. Re: Where is the Temperature flap motor?
    Jan 2012
    how fantastic!
    thanks for those links.
    much appreciated.
    john.
  7. Re: Where is the Temperature flap motor?
    Feb 2010
    Cambridge
    Well scan was done today and no fault codes..So he did some things through vcds to reset the flap motors.
    On a 1 hour drive the problem still happened, but did seem to cure itself after a few mins (which it wasn't doing before) so I assume there must be a sticky motor somewhere. Is there anything you can run through the air con system to clean these things?
    A6 3.0 TDI Le Mans
  8. Re: Where is the Temperature flap motor?
    Sep 2011
    The only thing I seen is a air con sanitizer http://www.autoglym.com/enGB/product...Q=FFLH&Range=1
    What a shame about scan...
    Blue = Windscreen+door windows vent
    Green = Front footwells(below dash) + Rear footwells (under front passenger seats)
    Red = Center vents above A/C controls
    Orange = Rear center console + "B" pillar rear vents
    Yellow = Left+Right Dash vents + Indirect ventilation vent (denoted by Yellow star only on "Dual Zone", sealed on "Basic")
    Only other info@present is read SSP 323 (pages 58,64 & 65) carefully, as it states air con unit differs depending in LHD/RHD cars...
  9. Re: Where is the Temperature flap motor?
    Feb 2010
    Cambridge
    Wow, didn't expect that. So do I need to completely remove the dash to get to that then?
    Not sure how easy that is, but I may get someone to do it for me.
    A6 3.0 TDI Le Mans
  10. Re: Where is the Temperature flap motor?
    Sep 2011
    Right I'm all posted out @ mo, will reply back tomorrow, some bits tricky others not, have seen this stuff when remove my interior twice...
  1. Audi A4 demister flap motor
    By plexman in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-11-2015, 08:10 AM
  2. airflow flap motor
    By mart2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2013, 01:27 AM
  3. Particle Regulator Motor/Position Flap Motor
    By Faye93x in forum Audi A3 - Archive Topics
    Last Post: 30-03-2009, 02:02 PM
  4. Air flap motor
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-11-2008, 10:19 PM
  5. golf mk4 1.8t fuel flap & resercualtion motor flap problem
    By shayd in forum Golf MK4 - 1999 - 2004
    Last Post: 25-04-2008, 05:50 PM
