Thread: Rattle when air con turned off
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
  1. Rattle when air con turned off
    Jan 2009
    Birmingham
    36 Post(s)
    Hi hope someone can help getting a rattle from the front of the engine when i turn the air con on it goes away car is running fine idles perfect cam belt was changed 7 months ago and about a year and half alternator pulley was done to im thinking it could be the aux belt tensioner or the pulley on the compressor any ideas people?
  2. Re: Rattle when air con turned off
    Sep 2008
    chester
    17 Post(s)
    I would check the compressor clutch,see if the nuts worked loose.
  3. Re: Rattle when air con turned off
    Jan 2009
    Birmingham
    36 Post(s)
    Quote Originally Posted by nevo View Post
    Already checked that and it's fine not loose
    If I just leave the ac on no noise so might just do that
    These clutches on the compressor are not cheap plus can't find where you can buy just the pulley would it need re gassing if I just changed the pulley iv got a denso compressor I thinks these came with a plastic pulley
  4. Re: Rattle when air con turned off
    Sep 2008
    chester
    17 Post(s)
    Get someone to operate the econ on/off and check where its eminating from,you should be able to do it in situ as long as there's enough clearance at the front,a degas will only be necessary if you have to remove the hoses.
  5. Re: Rattle when air con turned off
    Jun 2006
    Cardiff
    It's the AC compressor clutch, mine does the same thing. Pulley kit from TPS is £108.
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
  6. Re: Rattle when air con turned off
    Jan 2009
    Birmingham
    36 Post(s)
    Quote Originally Posted by pauldazzle View Post
    so did you change yours?
  7. Re: Rattle when air con turned off
    Jun 2006
    Cardiff
    No I haven't bothered yet as it looks like the front bumper, rad etc has to be removed to get proper access. I just leave the AC on, as like yours it only makes a noise when set to econ.
  8. Re: Rattle when air con turned off
    Jan 2009
    Birmingham
    36 Post(s)
    Hi just a option the rattle we are getting is the rubber dampers worn in the pulley found a site were you can just buy the rubbers instead of the whole pulley assy 6 rubbers fit in the pulley to dampen the noise when air con is off here the link http://www.mavoyparts.com/BUMPER,_RU...4_3818584.aspx
    what you think guys cheap option
  9. Re: Rattle when air con turned off
    Jul 2011
    Kilmarnock, Ayrshire, Scotland
    Its would be worth trying it, due to the low cost instead of £108 for the kit
    2008 A4 B8 Avant 143 2.0 TDI & 2014 Skoda Superb Comb 4x4 170CR 2.0 TDI DSG
  10. Re: Rattle when air con turned off
    Jun 2006
    Cardiff
    Very useful link. It is the rubbers that wear out causing the rattling. Mine had worn away to the size of a pea!!
  1. Air con rattle
    By Dave Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-07-2011, 05:17 PM
  2. A4 B7 with a rattle related to the air con
    By ming in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-08-2010, 10:58 PM
  3. Vibration when air con turned to 'econ'
    By skymaster in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-04-2010, 10:10 PM
  4. Air con rattle
    By coupe2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-02-2009, 02:11 PM
  5. rev drop when air con turned on
    By ritter1 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-01-2009, 04:45 PM
