Hello everyone. Thanks for taking a look at this, I'm hoping to upgrade to a S4 b7 but I've seen back reports on there timing chains and cylinder bore ware.
I can't understand why they manufactured these engines without steel cylinder bore liners. I've read that they can start using alot of oil caused by worn or scored cylinder bores, this can lead to serious engine failure..... Broken pistons and rods. Also worn valve guides causing the valves to stick open therefore being smashed by the piston Does anyone know if the RS6 C5 V8 suffers with these problems?
