Thread: Help on two DTC
Results 1 to 10 of 14
  1. Help on two DTC
    May 2012
    North Queensferry
    Morning folks,
    I'm getting the following two DTC on my 2001 A4 2.0 20V (ALT) 104,000 miles. Does anybody know what the most common cause of these faults. Also, should I clear the codes or wait till i've swapped a sensor/carried out repair. Any help would appreciated as money is tight and don't want to send to garage. I've cleared the codes once but they came back within 20 miles.
    Its been an expensive two months :- vacuum pipe, temp. sensor, thermostat housing and crank shaft sensor. Mr Audi has a big smile at the moment as his pockets are full.
    Rocketman
    17536/P1128/004392 - Fuel Trim; Bank 1 (Mult): System too Lean
    17545/P1137/004407 - Fuel Trim: Bank 1 (Add): System too Rich
  2. Re: Help on two DTC
    Oct 2005
    Too rich and too lean at the same time?
    In the words of the masters - Have a read of this
  3. Re: Help on two DTC
    May 2012
    North Queensferry
    Thanks Sam,
    Reading the info it looks like it may be a faulty MAF sensor.
    Does anybody know if a can get these online as I guess it will cost less than my local audi parts dealer. I believe its a bosch part, not audi.
    Trev
  4. Re: Help on two DTC
    Oct 2005
    Buy genuine only and do check with your dealer first - hopefully you'll be surprised at the price.
    If you're not surprised, we have a whole host of suppliers on board - just follow the link in my signature to the Sponsor section and take your pick
  5. Re: Help on two DTC
    May 2012
    North Queensferry
    Sam
    £98.94 plus vat for MAF sensor from local audi dealer. I'm going to go for this as its not as bad as I thought it would be. Along with the £98.94, I must hand back the faulty unit or face another £45 surcharge (I've already removed it). I pick it up on friday so I'll let you know if its the answer to my problems.
    Trev
  6. Re: Help on two DTC
    Jun 2006
    Cardiff
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
  7. Re: Help on two DTC
    May 2012
    North Queensferry
    Only time will tell. Will keep you updated.
  8. Re: Help on two DTC
    Jun 2006
    Cardiff
    In the past I've only ever seen those codes when the 1 of the 2 oxygen sensors has failed.
  9. Re: Help on two DTC
    May 2012
    North Queensferry
    The speed pickup is a bit vauge sometimes when you put the foot down. Just doesn't feel right. I think I'll try MAF sensor first as its done 104,000, which is no shame. Bosch say they have had some go at 40,000, due to poor maintenance (dirty air filter).
  10. Re: Help on two DTC
    Jun 2006
    Cardiff
    You can clean the MAF with Isopropal (from Maplins). Remove the sensor from the MAF housing which you'll need a set of torx security keys for. Get a freezer bag & spray the Isopropal in, submerge the sensor in it for 1/2 an hour or so giving it a bit of a shake now & again. Let it dry out & refit.
  1. Dtc 00575
    By chris_r in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-12-2010, 11:59 AM
  2. A3 3.2 DTC Location
    By granite911 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-08-2010, 12:14 PM
  3. all road DTC
    By Mr M. Onkey in forum VCDS - General Questions
    Last Post: 23-01-2009, 08:51 PM
  4. DTC Code
    By Dave2 in forum VCDS - Help Requests
    Last Post: 04-12-2008, 12:04 PM
  5. Vw Dtc 19463
    By Delco in forum Polo - Derby - Lupo - Fox
    Last Post: 20-11-2008, 11:05 AM
