Thread: help with vcds fault codes
  1. Re: help with vcds fault codes
    May 2012
    scotland
    thanks again, tryed disconecting my maf today and it was worse went lummpy and wouldn`t rev past 2000rpm and put the epc light on i never took it a run tho, i noticed that the inelt could be doing with a good clean while doing this, think al take the throttle body off tomorrow and have a nosey,im gonny try get it back on vag-com and scan it separate
  2. Re: help with vcds fault codes
    Jan 2010
    Essex UK
    Found this, it's not directly your problem but same code & a scan of just the engine control module produced a code
    ESP light on 01314 and 17656 codes
    so assume scanning your ECM will also do this. Note; it may flag up a code because you ran the engine with the MAF disconnected yesterday so may pay to scan, delete any code (after noting what it said) then re-scanning to see any "permenant" code.
    Sorry I can't be of much more help, if you don't get any joy from this then it might pay you to start another thread in the specific forum for your car rather than the VCDS one?
  1. VCDS Codes list for Ibiza 6L type MK4
    By shivy in forum Ibiza - Cordoba
    Last Post: 14-05-2012, 09:43 PM
  2. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  3. Just bought VCDS and need some help with Passat FSi codes
    By nr800 in forum VCDS - Help Requests
    Last Post: 21-11-2010, 08:21 PM
  4. VCDS/VAG COM codes for enabling/disabling options on the B6
    By Crackman 619 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-08-2010, 10:01 PM
  5. A6 2.7t engine and hvac. a few codes from vcds
    By jontawn in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-03-2010, 09:31 PM
