hi,
i got my car scanned today and im needing somehelp to understand the codes and what neeeds to be done to fix it,
Sunday,27,May,2012,14:47:07:40122
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
15-Airbags -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: None
Part No SW: 03C 997 057 C HW: Hardware No
Component: MED 9.5.10 00 7330
Revision: 00000000 Serial number: VWZ7Z0D9133539
Coding: 0002031
Shop #: WSC 00099 210 92237
VCID: 2E587549B90C649
No fault code found.
Readiness: 1110 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0019073
Shop #: WSC 01279 785 00200
VCID: 3A7049197544B89
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 K HW: 1K0 937 049 K*
Component: Bordnetz-SG 1.0 H30 0701
Revision: 00030000 Serial number: 00000000426390
Coding: 008D0F0600041800001400001400000000
Shop #: WSC 00000 000 00000
VCID: 3776502D4656A51
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 A HW: 1K0 909 605 A
Component: 0M AIRBAG VW8 022 0500
Revision: 04022000 Serial number: 0033FD074NH%
Coding: 0012365
Shop #: WSC 01268 785 00200
VCID: 2A50795985E4089
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 012 0030
Coding: 0000002
VCID: EFE6284DFE86AD1
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 950 P
Component: KOMBIINSTRUMENT VDD 3554
Coding: 0001401
Shop #: WSC 00821 210 90093
VCID: 356A5A255C5A571
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 2100103C14E2AD
Coding: 3D0F0140070003
VCID: 2756806D96F6351
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3554
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0116
Coding: 0000052
VCID: 30646B31A338729
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 E
Component: EPS_ZFLS Kl.0 1202
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 00E802087F2D8404085B0100
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
VCID: 31626E35A8327B1
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 G
Component: Radio BNO 0013
Coding: 0020200
1 Fault Found:
00003 - Control Module
014 - Defective
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 56: DTCs cleared
Chassis Type: 1K0
15-Airbags -- Status: OK 0000
Coding: 0002031
Coding: 0019073
1 Fault Found:
