Thread: Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
Results 1 to 10 of 19
  1. Question Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
    Mar 2011
    worcestershire
    Based in Worcestershire.
    How much should I pay for a Cambelt & Water Pump Replacement.
    Recommendations please for a good job
    55 plate 52k miles.
  2. Re: Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
    131 Post(s)
    1974 Post(s)
    Depending on where you go, who does the job and what parts are used (pattern or genuine) you can pay anything from £300 to £450 for this job. If no mention is made of new engine mount bolts, walk away and find someone who knows what they are doing.
  3. Re: Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
    Mar 2011
    worcestershire
    Water Pump as well?
  4. Re: Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
    Mar 2011
    worcestershire
    Timing Belt Kit
    CONTITECH - Ref: CT1028K3
    IS THIS A STRONGER BELT?
  5. Re: Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
    i had my bora done in november,along with water pump, using " a genuine volkswagen kit"
    it's a 130 pd asz engine,
    by the vag indy from where i bought the car 5yrs ago.
    no mention of new engine mounting bolts.
    are these included in a "genuine vw kit" ?
    if not, why would they not be included ,if they were needed?
    i feel my indy have given me excellent service with mot's-/ repairs since i purchased the car from them,
    would recommend anyone to them, feeling that you couldn't find a better/reasonably priced /totally professional outfit,
    available to meet customers needs over the entire weekend.
    new mounting bolts when changing timing belt?
    they must be "use once only" crap?
    can understand removing front mount to gain access to timing cover/belt,
    but not being able to re-use mounting bolts seems to be taking it just a little too far.
    regards,
    stewy.
    4th cog,--two to go
  6. Re: Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
    Oct 2009
    oldham
    hi
    I put a gates kit on my 55 reg golf sdi a few months ago, I also changed the engine mount bolts. My friendly vag parts man assured me that their mechanics didn't routinely change them with the belt kit. They don't cost much money so I changed mine just in case. I only change a water pump when they leak, mind if you don't do the work yourself I can see the logic in it. All in all the job cost me about £65, that included tippex and a budgie mirror. A fairly straight forward job.
  7. Re: Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
    131 Post(s)
    1974 Post(s)
    The bolts for the engine mount to the inner wing and from the consul to the mount are one time only stretch bolts. The consul to the block are sometimes one time only but there have been cases of these coming loose and destroying the block.
  8. Re: Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
    Mar 2011
    worcestershire
    Took the plunge & replaced Cam Belt, Tensioner & roller myself.
    Also purchased small trolley jack & belt locking kit.
    Job not rushed & also found very helpful guide on "myturbodiesel" forum.
    Wellchuffed as quoted £290 to £350
    My total cost Kit £79 + Trolley Jack £35 + Belt Locking kit £10.99.
  9. Re: Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
    131 Post(s)
    1974 Post(s)
    You didn't replace the consul and engine mount bolts then?
  10. Re: Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
    Mar 2011
    worcestershire
    You are correct Crasher. When I had quotes these parts were not mentioned.
    I am not totally sure what these are, can you help & give part numbers please.
    Thank you
  1. Question Water pump/Cambelt replacement
    By Mark Sommers in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-07-2010, 08:28 AM
  2. cambelt, pulleys, water pump
    By daveyboy467 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-10-2009, 12:25 AM
  3. A6 1.9tdi se 04 Tandum Pump Cost
    By tuksumdoin2 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-02-2009, 09:58 PM
  4. golf tdi BKC engine
    By shaungriff in forum Golf MK5 - 2004 - 2009
    Last Post: 03-09-2008, 06:53 PM
  5. Question How to tell is Cambelt and Water pump have been done?
    By tomjj in forum Golf MK5 - 2004 - 2009
    Last Post: 26-08-2008, 05:27 PM
