Thread: Vag-com Question-help!
  1. Vag-com Question-help!
    Hi all, i have vag-com 409.1 shareware which i use on my laptop using usb port,is there a 'crack' available?
    Basically if i connect to my car and go into 'ENGINE' and then 'FAULT CODES' it will come up with faults.
    I can read one fault but cant read the other faults it says ''shareware version'' is there a crack i can use? im using this via usb port
  2. Re: Vag-com Question-help!
    Oct 2005
    Lutterworth
    Yes, it is quite straight forward.
    You go to the Ross Tech website and pay the measly sum of $99 which is about 1/2 hours of main dealer labour, and they send you the crack.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
  3. Re: Vag-com Question-help!
    7 Post(s)
    Quote Originally Posted by Lex Luthor View Post
    Couldn't have said it better.
    The thing you need to remember is that Rosstech who produce vagcom are a small family business. They heavily invest in research to provide us lot with vagcom.
    If you had a Ford, Vauxhaul, Citroen, Renault, Peaugot etc etc, there simply isn't anything like it. Vagcom makes running a VAG vehicle unique in that you can cheaply maintain it yourself.
    Supporting Rosstech is well worth the measily investment as Lex has said above in that the cost would be recouperated almost the first time you use it.
  4. Re: Vag-com Question-help!
    May 2007
    knee deep in clunge
    14 Post(s)
    and so say all of us.
  5. Re: Vag-com Question-help!
    Mar 2008
    High Wycombe
    Quote Originally Posted by PungieEC View Post
    Here is a nice little fix I made for the problem
    Share it and spread it!
    Enjoy
    I suspect you're going to get banned (or at least warned) for that!
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  6. Re: Vag-com Question-help!
    Quote Originally Posted by vw754 View Post
    The program and VB6 source code:
    <link removed>
    Make sure you have the VB runtime installed. This you can get from Microsoft or just google it.
    Simply add the program file to your installed folder and change your desktop / Start menu shortcut to point to this file.
    This program will create the 3 binary files and will start vag com and monitor when those 3 files gets deleted and will create new ones all the time.
    Enjoy
    In the mean time I will be creating a open source project similar and will keep you updated.
    I cannot believe the sheer cheek of you two.
    3rd party cables are available for a pittence, rosstech are kind enough to still offer licenses for these cables, with the use of 409, for around £50 and STILL you try to rip it off.
    We all know piracy exists, but posting a link on an enthusiast forum, where your IP and email address has been recorded is just stupid, quite frankly.
    Post reported.
  1. Answer A Question & Ask Any Question?
    Last Post: 23-11-2011, 01:51 PM
  2. question?
    By minty0_10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-05-2007, 08:14 AM
  3. MPG question, AGAIN!
    By M4YTY in forum Passat - Archive Topics
    Last Post: 23-03-2007, 09:32 PM
  4. Sat nav question
    By melbar in forum Passat - Archive Topics
    Last Post: 12-03-2007, 08:12 PM
  5. GSM Kit Question
    By MoB in forum Chat - Completely Off Topic
    Last Post: 12-04-2005, 07:51 AM
