Thread: Engine management light not showing on Sharan 1.9 tid carat - 2003
Results 1 to 8 of 8
  1. Question Engine management light not showing on Sharan 1.9 tid carat - 2003
    May 2012
    Hartlepool
    Hi, went to MOT the car today and was told that because teh EML light is not showing when the ignition is turned to show the lights that it is an automatic failure!
    Anyone know how to fix this?
    Checked all the fuses I could see and they are OK - he also mentioned that the light for the stability program is not showing up as well which it should.
  2. Re: Engine management light not showing on Sharan 1.9 tid carat - 2003
    Pembrokeshire
    22 Post(s)
    have they ever shown ? a fault code read would be a start to see if any fault is there and whether the mil should be on.
  3. Re: Engine management light not showing on Sharan 1.9 tid carat - 2003
    May 2012
    Hartlepool
    I dont think so...would a generic reader get any error codes or does it need to be done @ VW dealer?
  4. Re: Engine management light not showing on Sharan 1.9 tid carat - 2003
    Pembrokeshire
    22 Post(s)
    a generic code reader will show an obd code so should do. you would probably need a more advanced reader to show the mil status and any manufacturers codes. see if there is someone close in the vcds section that could help. sometimes bulbs get taped over so you cannot see that the car has a fault, in order to sell it, or it could just be an electrical fault. if no codes are present and the mil is off, then you just need to suss out why it doesn't come on. same with the esp, but you would need a better code reader to look at that.
    Southern County Softy
    20 Post(s)
    A dashboard output test with VCDS would show if the light is working
    follow me on twitter...kiteaudi...
    A4 2.5 tdi QS (mapped)
  6. Re: Engine management light not showing on Sharan 1.9 tid carat - 2003
    Did you ever resolve this? Engine management light does not light on my 2004 Alhambra (4 clock dash) on startup but have had it from new and don't think it ever did.
    Also pretty unfair to expect a stability warning light to work on a car that doesn't have a stability control system. Don't think it was ever fitted to the 1.9tdi, 2.0tdi manual only. Suspect it might be the tester that's faulty rather than the car!
  7. Re: Engine management light not showing on Sharan 1.9 tid carat - 2003
    May 2012
    Hartlepool
    Hi, no I did not resolve the issue and I have sold the car since, I checked all the fuses and relays and they were fine, so it was looking like I would have to pul the instruemtn cluster out and have a look
    Oct 2010
    Here And There
    In MOT, it does not matter if a engine warning light is there, not there or indeed lit
  1. Sharan 1.8 Carat Gear Change Cables
    By antells in forum Touran - Sharan - Caravelle
    Last Post: 16-05-2012, 02:39 PM
  2. Question Sharan Carat Auto starting problem
    By geno101 in forum Touran - Sharan - Caravelle
    Last Post: 09-08-2009, 07:57 AM
  3. Please Help Engine management light is on, Fan turn on when engine is off, made the battery flat, help
    By shinghu in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2009, 02:15 AM
  4. vw sharan engine management light
    By scotspie501 in forum Touran - Sharan - Caravelle
    Last Post: 25-06-2008, 12:42 PM
  5. Should my Sharan VR6 Carat 1998 have Remote locking
    By dynamite71 in forum Touran - Sharan - Caravelle
    Last Post: 28-10-2006, 11:35 AM
