Thread: Audi A3 8P 2.0TDI CV boot/gaitor
  1. Audi A3 8P 2.0TDI CV boot/gaitor
    Feb 2010
    Bristol, UK
    I have searched and only found info for other vehicles like a passat apologies if linking to other sites is not allowed http://www.taligentx.com/passat/maintenance/cvjoints/
    2005 A3 2.0 TDI
    I need to change the CV boot on the OS outer cv joint, is it the same method. The outer drive shaft does not want to separate from the Hub at the moment
  2. Re: Audi A3 8P 2.0TDI CV boot/gaitor
    Near Blackpool
    48 Post(s)
    If you cant get enough leverage to pull the shaft out you need to disconnect wishbone and then you should be able to pull it out enough whilst hitting the drive shaft with a hammer and a punch.
  1. Gearstick gaitor removal Audi 80 2.6 Quattro 1994
    By quattro101 in forum 80 - 90
    Last Post: 04-01-2010, 09:58 PM
  2. Please Help My gaitor wont come off!
    By reggiepolo in forum Polo - Derby - Lupo - Fox
    Last Post: 12-10-2009, 01:13 PM
  3. gaitor trouble
    By snake in forum Chat - Anything with wheels
    Last Post: 23-09-2007, 07:45 PM
  4. Cv Gaitor spilt........
    By MrBush in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-06-2007, 03:46 PM
  5. CV gaitor replacement.......Help!
    By MrBush in forum Archive posts
    Last Post: 05-06-2007, 02:45 PM
