Thread: rough tickover, bouncy rev counter sationary with judder 2.0 tdi 140
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. rough tickover, bouncy rev counter sationary with judder 2.0 tdi 140
    Jan 2012
    nr bristol, somerset
    hi guys,
    just wondered if someone had and ideas what this might be? my (new to me) 2.0tdi 140, has, since end of january, had 2 turbos, egr valve, injector harness, missing bolt from throttle body and intercooler to cure P0299 underboost. what i am left with is a harsh tickover (when you key off your feet are actually tingling!!), and sometimes, when you stop at traffice lights, the rev counter will flick around, accompanied with a missfire and a juddering in the cabin. any help would be appriciated as i have been badly let down by the garage i bought car from, and a whopping mis diagnosis by bristol audi . thanks guys. john.
  2. Re: rough tickover, bouncy rev counter sationary with judder 2.0 tdi 140
    Cheshire
    Year, CR or PD engine (or engine code)?
  3. Re: rough tickover, bouncy rev counter sationary with judder 2.0 tdi 140
    Jan 2012
    hi there. engine code is BRE. year is 2007 56 plate. it is a PD engine. Also, i have noticed that when the revs are really bouncing around on tickover, there is no vibration back up thru clutch pedal, as in DMF, but, if you turn air con on, it stops. turn it off (Econ button), it starts again. also doesnt do it all the time. thanks guys. john.
  4. Re: rough tickover, bouncy rev counter sationary with judder 2.0 tdi 140
    Cheshire
    Initial thoughts from my experience of other cars would be EGR valve but I am no expert. But this does not tie in with you already having the EGR valve replaced?
    Anyway, I hope someone more experienced will also give you some input.
  5. Re: rough tickover, bouncy rev counter sationary with judder 2.0 tdi 140
    46 Post(s)
    Quote Originally Posted by johnnyone View Post
    hi there. engine code is BRE. year is 2007 56 plate. it is a common rail engine.
    It's PD - CR only came in the V6's and 2.0 TDi's on the facelift cars
  6. Re: rough tickover, bouncy rev counter sationary with judder 2.0 tdi 140
    Jan 2012
    ok, thanks for that. i know it has a brand new Audi EGR valve on it, as i have the receipt and you can plainly see it is new. i have been reading other posts about cam timing, and software updates ref lean fuel mixture without air con being on (fueling increased by ecu to compensate air con loading??), alternater clutches - all sorts!!!!
  7. Re: rough tickover, bouncy rev counter sationary with judder 2.0 tdi 140
    Cheshire
    It is a shame you are not close to Notts where you could go and see Crasher.
  8. Re: rough tickover, bouncy rev counter sationary with judder 2.0 tdi 140
    Jan 2012
    absolutely. could really do with someone who understands these engines to help me now.... john.
  9. Re: rough tickover, bouncy rev counter sationary with judder 2.0 tdi 140
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by bennettp23 View Post
    I'm experiencing some issues with my car mate, if I don't end up Crasher's workshop (as site sponser) then my next stop is a local workshop...
  10. Re: rough tickover, bouncy rev counter sationary with judder 2.0 tdi 140
    Jan 2012
    Quote Originally Posted by gupsterg View Post
    there is Dialynx near Swindon... http://www.dialynx.co.uk/
    http://www.youtube.com/watch?v=kwG_mv_wq6U
    met him in person great guy, I'm experiencing some issues with my car mate, if I don't end up Crasher's(as site sponser) then Kieth's place is next stop...
    thanks for that. i will take a look at link in a mo.
    i can't reply to your pm's (not enough posts yet!!), but i will put costs on my post soon and thanks for your interest..
    best regards john.
  1. Rev counter Golf tdi
    By A8-TDI in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 04-07-2010, 03:03 PM
  2. Please Help 2.0 tdi wont rev or tickover??
    By MRGSLINE in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-04-2010, 03:14 PM
  3. Please Help TDi Caddy Oil Warning and Rev Counter troubles
    By GusTDi in forum The Commercial Range
    Last Post: 10-07-2009, 10:08 PM
  4. Rev counter in my ´93 TDI????
    By skibonitten in forum 80 - 90
    Last Post: 12-09-2008, 10:20 AM
  5. Audi 80 tdi rev counter oil light problems
    By john milenkovic in forum 80 - 90
    Last Post: 24-04-2006, 07:06 PM
