Thread: Bora 99V gear change stiff problem
  1. Bora 99V gear change stiff problem
    Aug 2007
    Hi all,
    just got a VW Bora 99V, with 65000 miles, my problem is that the gear change is stiff, in all gears (manual box fitted), any ideas would be appreciated. I noticed with a search of the forum, someone changed a plastic unit on the selector/ gearbox, located somewhere under the air box and fixed a stiff change problem on a golf, could this be the fix for me?
    thanks in advance.
    psxnut
  2. Re: Bora 99V gear change stiff problem
    Dec 2008
    6 Post(s)
    did you ever find out ? i have the same problem
  3. Re: Bora 99V gear change stiff problem
    Aug 2007
    Yes I did fix it, I just sprayed loads of penetrating oil on the UJ's and kept changing and jiggling the gear stick, it was as simple as that. No parts needed. Try it, it may be all you need to do.
    psxnut
  4. Re: Bora 99V gear change stiff problem
    Dec 2008
    6 Post(s)
    Quote Originally Posted by psxnut View Post
    psxnut
    thanks for that, how would that relate to a passat, where are the uj's on mine, any idea ?
  5. Re: Bora 99V gear change stiff problem
    Aug 2007
    I would locate the steering shaft, where it comes out from the bulk head into the engine bay and the uj's should be before it joins the steering rack. I assume that they are similar on your passat, if not sorry to confuse. Anyway good luck.
    psxnut.
  1. stiff gear change - passat V6 4motion
    By richards in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-10-2009, 11:32 PM
  2. VW BORA- Gear Shift problem
    By Lyndon in forum Bora - 1998 - 2005
    Last Post: 25-07-2007, 09:36 AM
  3. VW T4 2.4 (94) Strange Gear Change Problem
    By holbornes in forum The Commercial Range
    Last Post: 21-07-2007, 11:04 AM
  4. Footwell water leak / first gear is stiff
    By stejuk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-06-2007, 11:03 PM
  5. Passat Gear Selection Stiff
    By chrisball666 in forum Passat - Archive Topics
    Last Post: 21-04-2007, 10:57 PM
