Thread: How many songs on a SD card on RNS-E?
  1. How many songs on a SD card on RNS-E?
    Mar 2012
    London, England
    Hey guys, I have a 4gb card in slot 1 of my RNS-E. My unit is running firmware 0650.
    As far as I am aware, the RNS-E can play 400 mp3s per card, or 512 mp3s if they are in folders.
    I have made 2 folders in the card like below:
    SD Card 1:
    Folder 1 > 255 mp3 songs
    Folder 2 > 255 mp3 songs
    All my songs still don't show up. What am I doing wrong?
  2. Re: How many songs on a SD card on RNS-E?
    Aug 2009
    Near Lanark
    21 Post(s)
    first thing to check....are they all at a compatible bit rate?
    I've converted many of my cds but for some reason, some mp3s convert at an unusual or variable bit rate. The car needs 112, 128, 160, 192 etc. But playing them on your computer will be no problem so unless you check the bit rate is a constant 128(for example) it might not play.
    I'd also try a few of the songs rather than both folders with 255 in each....reduce the number of tracks and see if that makes a difference.
    Finally......the RNS-E will not play SDHC cards....so your 4gb MUST be SD....not SDHC. They do exist but they're not common. Try a different card - it might be that regardless of bit rate or song quantity, the unit will never read the card.
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  3. Re: How many songs on a SD card on RNS-E?
    Mar 2012
    London, England
    I have a mixture of MP3s from 16 to 320 kbps bit rate. Is this a problem?
    My card is a rare SD card, from Amazon, the card works fine.
    If the unit supports 512 tracks then it should be fine right? What would reducing the number of tracks do?
    What about splitting them into more folders?
  4. Re: How many songs on a SD card on RNS-E?
    Southern County Softy
    20 Post(s)
    try re-formatting the card to FAT 32, then add 1 of the folders and see if it works.
    A4 2.5 tdi QS (mapped)
  5. Re: How many songs on a SD card on RNS-E?
    Mar 2012
    London, England
    Quote Originally Posted by kite View Post
    So if I format it and put only one folder, I'm guessing put all the 510 songs in there? If I put less in there I wouldn't know if its working?
    20 Post(s)
    Just add 1 folder with 255 and try first before adding the other folder
    follow me on twitter...kiteaudi...
  7. Re: How many songs on a SD card on RNS-E?
    warp_speed Guest
    There is also a limit on the file name length. I ran into this problem were some songs were not showing. Can't remember the length limit, google should help you out.
  1. Question RNS E SD Card Slots
    By monz87 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-05-2012, 11:06 PM
  2. Sat Nav on RNS-e - can it be run from an SD card
    By andyha2000 in forum In Car Entertainment
    Last Post: 17-11-2011, 08:55 AM
  3. Question What SD card do I need to use in RNS-E system ?
    By onionman100 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-10-2011, 11:35 AM
  4. RNS-E Memory card size
    By Ben in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-10-2009, 07:31 PM
  5. Please Help RNS-E SD Card Playlist Random Change
    By dan9999 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-05-2008, 07:34 PM
