Thread: audi a4 2.0tdi rough running & excess white some when cold
  1. audi a4 2.0tdi rough running & excess white some when cold
    Hi all,
    we have an audi a4 ,when started from cold runs very lumpy (slight misfire) & has excess white smoke,when on road test at about 2000rpm very jumpy.no fauts codes.
    checked compressions all good,
    re flashed ecu
    ok heres what i have replaced
    fitted 4 new injectors from tps & loom in head & glow plugs
    new inlet manifold
    new cylinder head
    new egr valve
    throttle valve as old one full of oil
    checked turbo shaft for play looks ok
    checked egr cooler & smoked tested then smoked tested all system
    drain fuel tank changed fuel filter checked intank pump
    changed fuel pump on back of cylinder
    checked timming all good there
    car runs better when hot with no smoke on tick over
    any help would be great
    thanks lee
  2. Re: audi a4 2.0tdi rough running & excess white some when cold
    May 2007
    knee deep in clunge
    14 Post(s)
    Check the measured value blocks 18 (all values 0) and 23 (values: -80 µs in the idle speed, -100 µs at 1500 rpm). If the value is over 100, this may be a sign of air in the fuel system.
    Fit a clear fuel pipe and check for air on start up. Also check coolant and fuel temp reading before starting
    make sure you have .50 bar before the tandem pump residual pressure and check the egr cooler change over is working on the cooler pipe
    make sure the valve timing in measured value block 4 zone 4 is around 2.5 as well
    also the egr wiring loom can take on oil back to the ecu and cause similar issues, disconnect the egr plug and look inside the pins for oil.
    blank off the egr pipe as well to rule out leaking egr gas putting dirty air in as egr is active upto 2000 rpm so kind of matches your symptoms
  3. Re: audi a4 2.0tdi rough running & excess white some when cold
    thanks for your reply a8 tech, with regards to checking egr cooler when would should the change over take place,
    lee
  1. Please Help Engine running very rough when cold
    By eurobenjy in forum Golf MK4 - 1999 - 2004
    Last Post: 29-12-2012, 04:37 PM
  2. Cold running engine, excess oil from inlet manifold
    By borabear in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-11-2012, 09:16 PM
  3. Please Help Fuel additive caused rough running & white smoke
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-10-2009, 04:39 PM
  4. mk4 gti turbo rough running when cold
    By superkev in forum Golf MK4 - 1999 - 2004
    Last Post: 22-07-2009, 12:34 PM
  5. Difficulty starting and rough running when engine is cold
    By brauser rexel in forum Archive posts
    Last Post: 23-10-2007, 04:50 PM
