Thread: 3.0tdi Allroad brake fault alarm on switch on.
Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 94
  1. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #41
    Nov 2010
    Watford
    Hi Gupsterg,
    This only happens when I turn the key to position one, when the dash lights come on. If I turn the key off and then one again once or twice the fault goes away. I guess it has something to do with when the modules etc, power up. Once the dash has reset e.g. esp and glow plug lights go out it starts perfectly with no problems at all when running.
    I'm thinking possibly that dodgy battery volts/amps, voltage controller or something like that causing the modules to do a wobbly.
    Can a faulty key cause any problems as they are a lot more complex than just engine immobilisers, with their memory function. One other thing I have noticed is that sometimes (but not very often) when I unlock the car not all the doors unlock and I have to unlock again. Probably not related, just clutching at straws.
    Audi Allroad 3.0tdi. Tiptronic. 12/12/2006. Full Phantom Black, 19" alloys, MMI high, Navigation, Phone prep, Heated sports seats with memory, Parking advanced with rear camera, Sunroof, Rear blinds.
  2. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #42
    Sep 2011
    Lurking over a keyboard ...
    If fault with key I would assume log would show, but if you wanna check some measuring blocks, with VCDS access module [05]
    Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Access/Start Auth. J518
    Measured value block 11:
    Bit 7 ...<--... Bit 0
    '0 0 0 0 0 0 0 0'
    1. Remote control key '0 0 0 0 0 0 0 0'
    (Bit 7-4: (0 = ID sender unknown); Bit 3: Battery (1 = Low); Bit 2: open; bit 1: Rear; Bit 0: close)
    2. RRC (command from J518 on CAN) '0 0 0 0 0 0 0 0'
    (Bit 7: Wrong response; Bit 6: No response; Bit 5: Carfinder error; Bit 4: CAN Carfinder;
    Bit 3: CAN PANIC; Bit 2: CAN Rear; Bit 1: CAN Close; Bit 0: CAN Open)
    3. Reception strength of remote control key
    (hold remote control key directly against rear window when operating)
    If the value is less than 170, check the battery in the remote control and the connection from the electronic ignition lock -E415 to the aerial according to the current flow diagram.
  3. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #43
    Nov 2010
    Watford
    For the last couple of weeks I hadn't had any problems but today the same fault was back with vengeance. I was stuck in the school car park with the dash lights all on, brake fault on DIS and an alarm bleeping but this time turning the key on and off didn't work. The car would not start, my 4 year old sitting in the back asking me if the problem with the car was back. He then sweetly told me he would help me fix it when we got home. After about five mins of turning the key on and off the dash lights came on normally and the car started fine.
    I'm sure that when this happens the car doesn't 'click' the same. Normally when I turn the key I here several clicking noises from around the car which I assume are solenoids switching. I think it doesn't sound the same when this problem occurs.
    Could a bad solenoid be causing this? Which solenoids come in to use when you turn the key to position 1?
    I have read the fault codes again and they are listed. It does seem to list faults which occurred today and another lot which occurred last month. I haven't noticed any other problems when driving the car and have no idea if they are in any way related.
    How can I get help from a8 tech? It seems he has a great knowledge of audis and I would really appreciate his ideas.
    I'm going on a family trip to France for our holiday next month and would really like to have fixed this before I leave, I don't what the worry of breaking down over there and ruining the hols.
    01-Engine -- Status: Malfunction 1010
    02-Auto Trans -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 402 S HW: 4F0 907 401 C
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H03--- Serial number:
    Coding: 0011372
    Shop #: WSC 02334 785 00200
    VCID: 2D573FEDB40A1F1
    1 Fault Found:
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 001 - - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: -195.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 12.16 V
    Bin. Bits: 00101000
    Torque: 0.0 Nm
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 K HW: 09L 927 156 C
    Component: AG6 09L 3,0 TDI RdW 0040
    Revision: --H01--- Serial number: 4236818
    Coding: 0000001
    2 Faults Found:
    006273 - Powertrain Data Bus: Missing Message
    P1881 - 000 - Acceleration Request - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 3
    Mileage: 94535 km
    Time Indication: 0
    Date: 2012.06.16
    Time: 09:10:35
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 30.0
    (no units): 25.0
    Temperature: 52.0∞C
    T.B. Angle: 60.0∞
    049408 - No Communication with Engine Control Module (SAE
    U0100 - 000 - ECM/PCM) - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 3
    Mileage: 94535 km
    Time Indication: 0
    Date: 2012.06.16
    Time: 09:10:35
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AB HW: 4F0 614 517 R
    Component: ESP 8.0 quattro H05 0040
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0016776
    VCID: 64C19AC9A7409E9
    2 Faults Found:
    01314 - Engine Control Module
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 64
    Mileage: 94776 km
    Time Indication: 0
    Date: 2012.07.03
    Time: 12:17:46
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x02A2
    Hex Value: 0x0013
    Hex Value: 0x857F
    Hex Value: 0x00FF
    02083 - Message for Delay Request
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 64
    Mileage: 94776 km
    Time Indication: 0
    Date: 2012.07.03
    Time: 12:17:43
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x02A2
    Hex Value: 0x002B
    Hex Value: 0x0592
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601100539500
    Coding: 0000147
    VCID: E3C319D5224E191
    Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    No fault code found.
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 E HW: 4E0 035 729 A
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 351IP067525523
    Coding: 0003302
    Shop #: WSC 00720 210 91832
    VCID: 2645C0C191FC2C9
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H02 0060
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 N
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000031 Serial number: 00000000313892
    Coding: 0001302
    VCID: DBB321351A3E211
    1 Fault Found:
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 64
    Mileage: 94776 km
    Time Indication: 0
    Date: 2012.07.03
    Time: 12:15:24
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H15 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0001101
    Shop #: WSC 02335 785 00200
    VCID: 316F239DA8327B1
    Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H04 0190
    Coding: 00064784
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBF8194089
    Shop #: WSC 00000 000 00000
    VCID: 1C31E229DFB0E69
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH29 0280
    Revision: 08H29000 Serial number: 0037LD0GTURH
    Coding: 0013381
    Shop #: WSC 02325 785 00200
    VCID: 295FCBFD80E2031
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenks‰ulenmodul H08 0230
    Revision: 00H08000 Serial number: 90026062640222
    Coding: 0102142
    VCID: E6C500C1D17C6C9
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4F0 920 981 F
    Component: KOMBIINSTR. M73 H18 0120
    Revision: 00500000 Serial number: 5HS37UK96
    Coding: 6185443
    Shop #: WSC 00402 210 13626
    VCID: 2343D9D5E2CED91
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 28
    Reset counter: 64
    Mileage: 94535 km
    Time Indication: 0
    Date: 2012.06.16
    Time: 09:10:37
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1100B0871980B4
    Coding: F5D1DE5F30320600
    Shop #: WSC 00016 210 69841
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 43
    Mileage: 94535 km
    Time Indication: 0
    Date: 2012.06.16
    Time: 09:10:35
    Address 34: Level Control Labels: None
    Part No SW: 4F0 910 553 A HW: 4F0 907 553 A
    Component: J197 LUFTFEDER H17 0060
    Serial number: 00619002170400
    Coding: 0000210
    VCID: 224DDCD1FDD4D09
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 29
    Reset counter: 64
    Mileage: 94535 km
    Time Indication: 0
    Date: 2012.06.16
    Time: 09:10:35
    01316 - ABS Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 20
    Reset counter: 64
    Mileage: 94535 km
    Time Indication: 0
    Date: 2012.06.16
    Time: 09:10:37
    Address 36: Seat Mem. Drvr Labels: None
    Part No SW: 4F0 910 760 HW: 4F0 959 760
    Component: Sitzmemory FS H04 0050
    Revision: 00000000 Serial number: 00000000896400
    Coding: 0091138
    VCID: E1CF13DD38520B1
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
    Component: MNS ECE H48 1060
    Revision: 00000000 Serial number: 364I+067593809
    VCID: 3B7301B57A7E811
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0170
    Revision: 00000000 Serial number: gAò
    Coding: 0003738
    VCID: 2C5132E98F10169
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01017343460000
    Coding: 0262907
    VCID: 2E5538E1B90C649
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 16
    Reset counter: 64
    Mileage: 94535 km
    Time Indication: 0
    Date: 2012.06.16
    Time: 09:10:37
    Address 47: Sound System Labels: 4F0-910-223-BO.lbl
    Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
    Component: DSP-High C6 H09 0240
    Revision: PROD_01 Serial number: 00000000019540
    Coding: 0000113
    Shop #: WSC 00720 210 91851
    VCID: 2547C7CDECFA271
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000287923
    Coding: 0001113
    VCID: DEB52821092C349
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 29
    Reset counter: 64
    Mileage: 94532 km
    Time Indication: 0
    Date: 2012.06.16
    Time: 09:10:00
    Freeze Frame:
    Voltage: 11.900 V
    Temperature: 28.0∞C
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0170
    Revision: 00000000 Serial number: E4ó
    Coding: 0003738
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
    Component: EPB CB4C0060 H04 0060
    Revision: --H04---
    Coding: 0000321
    Shop #: WSC 02324 785 00200
    VCID: 1F4BD525CEA6FD1
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 28
    Reset counter: 64
    Mileage: 94528 km
    Time Indication: 0
    Date: 2012.06.16
    Time: 09:10:35
    Freeze Frame:
    Voltage: 10.97 V
    Count: 241
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 384K-067627712
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000110730
    Shop #: WSC 00720 210 86430
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 2609151332
    Coding: 344630393135313035442056413032363039313531333332
    Shop #: WSC 00000 384 00290
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 64
    Mileage: 94776 km
    Time Indication: 0
    Date: 2012.07.03
    Time: 12:14:05
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0003074
    Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
    Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
    Component: J772__Rearview 0050
    Revision: --H12--- Serial number: 525PA8-J68305B
    Coding: 1020505
    VCID: 1E35E821C9ACF49
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0050
    Coding: 0003074
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
    Component: Parkhilfe 8-Kan H12 0060
    Revision: 00H12000 Serial number: 06330626802621
    Coding: 0221416
    VCID: 2859CEF99BE83A9
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 H HW: 4E0 862 335
    Component: Handyvorb2 H13 0700
    Revision: 00000000 Serial number: 00000007577872
    Coding: 0010920
    VCID: 275BCDC596F6351
  4. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #44
    Sep 2011
    Quote Originally Posted by gupsterg View Post
    The only person I can think of at mo (no offence 2 any of the other great posters) who could answer such a ??? is a8 tech
    LINK:- VW AUDI Forum - VWAF
    Click above link.... send PM...
  5. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #45
    May 2007
    knee deep in clunge
    14 Post(s)
    looks like a terminal 30 hanging so all the faults relate to engine ecu
    remove the passenger e box cover
    located nsf plenum chamber
    inside you will see the engine ecu and the supply relays
    check for water ingress and feedback your findings
  6. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #46
    Sep 2011
    Hi A8 Tech ...
    Advise sparker to do that post 5... post 7 sparker say
    Quote Originally Posted by sparker View Post
    I have checked under the bulk head trim, all dry as a bone, no sign of any water at all. Have check the drains before to make sure they where clear. Also had checked in the rear both sides as I know water can get in from leaking washer pipe (never use rear washer just in case ), also all the carpets seem dry too.
    then further data post 20
    Removed the cover on the ECU, just as you said the terminal connections have a metal plate riveted over them so it's not really possible to check their fit. Perfectly dry inside though so no damp induced problems.
  7. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #47
    May 2007
    knee deep in clunge
    14 Post(s)
    ok need to read drive train can status when the fault happens as well as voltage
    get the drivetrain from address 19 or 03 (measured value blocks)
    get the voltage supply to the ecu from address 01 if possible
    look at
    address 19
    Measured value block 125:
    Engine electronics (no readout/0/1/Sl.Ind.)
    Gearbox electronics (no readout/0/1/Sl.Ind.)
    Brake electronics (no readout/0/1/Sl.Ind.)
    Engine electronics II (no readout/0/1/Sl.Ind.)
    compare findings with
    Result: Meaning:
    No readout Control unit not coded in gateway
    0 No signal/communication or control unit in sleep mode
    1 Signal/communication (in control units of the drive train data bus this status is also if there is mutual shorting between the CAN-High and CAN-Low wires)
    Sl.Ind. Control unit ready to sleep
    1-wire One-wire mode (only possible in convenience system data bus control units)
    One-wire One-wire mode (only possible on convenience system data bus)
    Two-wire Two-wire mode
    address 01 mvb 95 and 96
    095 Starter control
    1) Terminal 50
    0 or 1
    2) P/N signal
    Only vehicles with automatic gearbox
    Signal from selector lever switch
    Interlock signal
    Only vehicles with manual gearbox
    Signal from clutch pedal switch for engine start
    0 or 1
    3) Starter relay 1
    0 or 1
    4) Starter relay 2
    0 or 1
    096 Starter control
    1) Terminal 50-back
    0 or 1
    2) Starter control shut-off conditions 1 (from 11.2005)
    X X X X X X X 1 Fault starter relay
    X X X X X X 1 X Fault P/N or interlock signal
    3) Starter control shut-off conditions 2
    X X X X X X X 1 Start rejection speed reached
    X X X X X X 1 X Road speed threshold
    surpassed
    X X X X X 1 X X Maximum start time depending on glow period
    surpassed
    X X X X 1 X X X Maximum start time exceeded
    X X X 1 X X X X Terminal 15 deactivated
    X X 1 X X X X X Terminal 15 lock
    X 1 X X X X X X Terminal 50 or 50-back missing
    1 X X X X X X X Starter activated, but engine
    speed is 0 rpm
    4)Vehicle voltage
    [V]
    2 1 0
  8. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #48
    Sep 2011
    A8 hope you don't think I'm being busy body...
    As been involved in thread and I know you are busy guy thought would answer your query...
    So OP ( sparker ) get resolution quicker...
  9. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #49
    May 2007
    knee deep in clunge
    14 Post(s)
    no problem
    these mvb's below are important
    address 05
    Measured value blocks for the entry and start authorisation control unit - J518:
    Measured value block 1:
    1. Terminal 15 (relay activation circuit) (on/off)
    2. -
    3. Terminal 75X (relay activation circuit) (on/off)
    4. Terminal 50 (relay activation circuit) (on/off)
    Measured value block 2: Entry and start authorisation button -E408
    1. ON button (on/off)
    2. START button (on/off)
    3. STOP1 button (on/off) *see also measured value 131
    4. Touch sensor (Bit 7-4: not used; Bit 3: RR; Bit 2: FR; Bit 1: RL; Bit 0: FL)
    '0 0 0 0 0 0 0 0'
    Measured value block 3:
    1. S-contact on data wire from entry and start authorisation switch E415 (on/off)
    2. Term.15 on data wire from entry and start authorisation switch -E415 (on/off)
    3. Term.50 on data wire from entry and start authorisation switch E415 (on/off)
    4. -
    Measured value block 4:
    1. Button E408 ON on data wire from switch E415 (on/off)
    2. Button E408 START on data wire from switch E415 (on/off)
    3. Button E408 STOP on data wire from switch E415 (on/off)
    4. Brake light switch F on data wire from switch E415 (on/off)
    Measured value block 5:
    1. Current recovery buffer
    2. Recovery data 0
    3. Recovery data 1
    4. -
    Measured value block 6:
    1. Serial bus
    2. Terminal 15R Relay working circuit (on/off)
    3. Terminal 75X Relay working circuit (on/off)
    4. Terminal 50R Relay working circuit * (on/off)
    *Not applicable as from model year 2006; no wire to relay in wiring harness.
    TG - Tailgate
    CL - Central locking
    ID - Identification sender
    Measured value block 7:
    1. Supply voltage of entry and start authorisation control unit -J518 (in Volts)
    2. Output voltage to activate terminal 15 relay (in Volts)
    3. Output voltage to activate terminal 75X relay (in Volts)
    4. Output voltage to activate terminal 50 relay (in Volts)
    Measured value block 8:
    1. -
    2. Entry and start authorisation switch -E415 Locked 1 (unpressed/pressed)
    3. Entry and start authorisation switch -E415 Locked 2 (unpressed/pressed)
    4. Entry and start authorisation switch -E415 Unlocked (unpressed/pressed)
    Measured value block 9:
    1. Test switch for motor rotation, ESL (unpressed/pressed)
    2. Test switch for motor rotation, ESL (unpressed/pressed)
    3. Term.15/P Wire from entry and start authorisation switch E415 (on/off)
    4. Term.50/S wire from entry and start authorisation switch E415 (on/off)
    Measured value block 10:
    1. Jump-start counter
    2. Unlock counter
    3. -
    4. Preset wait time
    '0 0 0 0 0 0 0 0'
    (Hold remote control key directly against aerial for central locking and anti-theft alarm -R47 "window aerial")
    4. -
    Measured value block 22:
    1. -
    2. -
    3. -
    4. Number of matched keys
    Measured value block 23:
    1. Authentication OK (yes/no)
    2. Engine control unit authorised (yes/no)
    3. Key ID (key identifier) authorised (yes/no)
    4. Immobilizer status:
    0 Tape end original state
    1 Tape end new
    20 Tape end programmed
    2x Tape end x.ECU learned (1<=x<=4)
    30 Tape end ESL (Electronic Steering Lock) learned
    3x Tape end x-th key matched
    6 Immobilizer adapted
    Measured value block 24:
    1. Immobilizer login block (for adaption) in minutes
    2. Remaining free starts (terminal 15 ON cycles)
    3. Drive enable
    4. Tape end timeout
    Measured value block 25:
    1. Warning text to dash panel insert J285 via CAN
    2. Message text to dash panel insert J285 via CAN
    3. Advanced Key error message
    4. -
    Measured value block 26:
    1. -
    2. -
    3. -
    4. Advanced Key: Total number of authentications
    Measured value block 27:
    1. Lockout time capacitive sensors (touch sensor, after locking of vehicle)
    2. False triggering configuration (counter reading at which the touch sensors shut off; anti-play protection)
    3. Current counter reading - false triggering due to operation of a touch sensor without valid key (anti-play protection). The counter runs down to zero starting from the configuration.
    4. -
    Measured value block 50: CAN values intelligent load module (ILM)
    1. Value received on CAN (ILM TG_MAIN_LATCH) (on/off)
    2. Value received on CAN (ILM LOCKED INTERNAL) (on/off)
    3. Value received on CAN (ILM LOCKED EXTERNAL) (on/off)
    4. Value received on CAN (ILM SAFED EXTERNAL) (on/off)
    Measured value block 51: Driver's door CAN values from door control unit (DCU)
    1. Value received on CAN (driver's door control unit open) (on/off)
    2. Value received on CAN (driver's door control unit locked) (on/off)
    3. Value received on CAN (driver's door control unit safed) (on/off)
    4. -
    Measured value block 52: Front passenger door CAN values from door control unit (DCU)
    1. Value received on CAN (front passenger door control unit open) (on/off)
    2. Value received on CAN (front passenger door control unit locked) (on/off)
    3. Value received on CAN (DCU_front passenger door safed) (on/off)
    4. -
    Measured value block 53: Rear left door CAN values from door control unit (DCU)
    1. Value received on CAN (rear left door control unit opened) (on/off)
    2. Value received on CAN (rear left door control unit locked) (on/off)
    3. Value received on CAN (rear left door control unit safed) (on/off)
    4. -
    Measured value block 54: Rear right door CAN values from door control unit (DCU)
    1. Value received on CAN (rear right door control unit open) (on/off)
    2. Value received on CAN (rear right door control unit locked) (on/off)
    4. -
    Measured value block 55: CAN values from door control unit (DCU)
    1. Value received on CAN (driver's door control unit opening) (0% ...) 100%)
    2. Value received on CAN (front passenger door control unit opening) (0% ...) 100%)
    3. Value received on CAN (rear left door control unit opening) (0% ... 100%)
    4. Value received on CAN (rear right door control unit opening) (0% ...) 100%)
    DD - Driver's door
    PD - Front passenger door
    RL - Rear left door
    HR - Rear right door
    ILM - Convenience (Intelligent Load Module)
    TG - Tailgate
    DCU - Door control unit
    TSS - Tilt/slide sun roof
    Measured value block 57: diagnosis
    1. Value received on CAN (Diagnosis 1 unlearn counter)
    2. Value received on CAN (Diagnosis 1 ERROR BIT MILEAGE) (on/off)
    3. Value received on CAN (Diagnosis 1 ERROR BIT TIME) (on/off)
    4. -
    MILEAGE - kilometres
    TIME - time
    Measured value block 58: Date
    1. Diagnosis 1 value received on CAN (Hour:Minute:Second Day.Month.Year)
    2. -
    3. -
    4. -
    Measured value block 80:
    1. ECU IDENT block 1
    - Manufacturer works number and identifier (7-digit)
    - Date of manufacture dd:mm:yy (8-digit)
    - Manufacturer modification status (8-digit)
    - Manufacturer test status no. (4-digit)
    - Manufacturer serial no. (4-digit)
    2. -
    3. -
    4. -
    ECU - Electronic Control Unit
    Measured value block 81:
    1. ECU IDENT block 2
    - Chassis number (17 characters, alphanumeric)
    - Module no. or serial no. (14 characters, alphanumeric)
    -Type test number (vacant)
    2. -
    3. -
    4. -
    Measured value block 82:
    1. ECU IDENT block 3
    - Flash tool code (FTC) (13 characters, alphanumeric)
    - Flash date "dd.mm.yy" ( 8 characters, alphanumeric)
    - Hardware module (3 characters, alphanumeric)
    - Hardware sort key (2 characters, alphanumeric)
    - Software module (3 characters, alphanumeric)
    - Software sort key (2 characters, alphanumeric)
    2. -
    3. -
    4. -
    ECU-IDENT - Electronic control unit identification
    Or-VIN - Original vehicle identification
    Measured value block 90:
    1. Value received on CAN (GATEWAY_2 Engine_1_old)
    2. Value received on CAN (GATEWAY_2 Clutch switch) (on/off)
    3. Value received on CAN (GATEWAY_2 Brake light switch) (on/off)
    4. Value received on CAN (GATEWAY_2 Brake test switch) (on/off)
    Measured value block 91:
    1. -
    2. Value received on CAN (GATEWAY_1 Selector lever position)
    3. Value received on CAN (GATEWAY_1 Brake_1_old) (on/off)
    4. Value received on CAN (GATEWAY_1 Gearbox_1_old) (on/off)
    Measured value block 128:
    1. Terminal S on CAN (on/off)
    2. -
    3. Terminal P on CAN (on/off)
    4. -
    Measured value block 129:
    1. -
    2. Gear position P (on/off)
    3. Gear position PN (active/inactive)
    4. -
    S - Start signal
    P - Park signal
    PN - Park/Neutral signal
    Measured value block 131:
    1. STOP button 1* (pressed/unpressed)
    2. STOP button 2* (on/off)
    3. -
    4. -
    *Measured value phased-in as from end of model year 2006
    Measured value block 137:
    1. Current locking voltage for steering column lock from entry and start authorisation switch -E415
    2. Preset minimum locking voltage
    3. -
    4. -
    BGW - Immobilizer identification number
    Measured value block 177:
    1. Value received on CAN (ILM rear 1 Softtouch pressed) (on/off)
    2. -
    3. -
    4. -
    ILM - convenience system
    Measured value block 178:
    1. Value received on CAN (driver's door control unit keyswitch close) (on/off)
    2. Value received on CAN (driver's door control unit day pressed) (on/off)
    3. Value received on CAN (driver's door control unit lock button) (on/off)
    4. -
    Measured value block 179:
    1. -
    2. Value received on CAN (front passenger door control unit day pressed) (on/off)
    3. Value received on CAN (front passenger door control unit lock button) (on/off)
    4. -
    Measured value block 180:
    1. -
    2. Value received on CAN (rear left door control unit day pressed) (on/off)
    3. Value received on CAN (rear left door control unit lock button) (on/off)
    4. -
    Measured value block 181:
    1. -
    2. Value received on CAN (rear right door control unit day pressed) (on/off)
    3. Value received on CAN (rear right door control unit lock button) (on/off)
    4. -
    ESL - Electronic steering lock
    DD - Driver's door
    RL - Rear left door
    TG - Tailgate
    ACAN - Drive train bus (CAN)
    2 1 0
  10. Re: 3.0tdi Allroad brake fault alarm on switch on.
    #50
    May 2007
    knee deep in clunge
    14 Post(s)
    focus on the ignition switch status !!!!!!!!!!!!!!!!!!!!!!!
    2 1 0
  1. Allroad Electric Mirror Switch
    By WesleyP in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-11-2011, 02:49 PM
  2. Fault codes - brake light switch
    By rabbie1969 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-08-2011, 06:31 PM
  3. Question Brake Switch Fault P0571/16955
    By vfrvulcan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2011, 09:17 PM
  4. Please Help Brake switch and brake pressure sensor issue??
    By P.M.G in forum Audi A3 - Archive Topics
    Last Post: 07-02-2009, 06:20 PM
  5. brake lights / brake switch recurring nightmare!
    By stuart40 in forum Chat - Anything with wheels
    Last Post: 16-09-2007, 11:23 PM
