Thread: How to clean door shuts?
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. How to clean door shuts?
    46 Post(s)
    I touched on this last night but need some answers - got a suggestion from Alann84 to use some Bilberry but need something to use everytime I clean the car.
    The 'slime' problem: looks like the car had been parked outside/under a tree by the previous owner
  2. Re: How to clean door shuts?
    Dec 2007
    Belfast
    Hi.
    If I was going to cleam my door shuts or hinges, I would use neat G101.
    Spray it on and adjitate with a paint brush, rinsing away with garden hose.
    Not advisable to use a pressure washer as the dirt will go everywhere.
    Keep applying the G101 and using the paintbrush until the job is done.
    One thing I would say is what you are trying to clean away mostly grease for
    the door hinge. When you finish your job, spray a lot of WD 40 around the hinge and then
    apply some fresh grease, otherwise a couple of days or weeks after you do this, you will have creakey
    doors when you open and close them.
    Good luck.
  3. Re: How to clean door shuts?
    Feb 2009
    Glasgow UK
    Hi Chris, I know the issue you speak of re the door shuts.
    Like my exhaust tips, I clean the door shuts and also the underside of the bonnet everytime I wash the car, once its done the first time, it literally adds a few minutes onto your routine. For me now, its just a very quick spray of APC and then a quick wipe with a microfibre and they're as good as new.
    Mark makes some good points.
    I'd also look to use a paintbrush, maybe 1" or similar, spray some APC ( All Purpose Cleaner ) or Bilberry would do the trick too I guess. Maybe go around and liberally spray them all, by the time you get round to the first one again it will have loosened any stubborn dirt / grime......agitate it with the paintbrush as required followed by another few squirts of your spray solution, then wipe clean, job done
    As Mark says, obviously follow up and re grease the hinges.
    Once you've done this, if you incorporate it into your routine it will only take a few minutes and you'll hardly notice the time, but will notice the door shuts every time you get in / out the car.
  4. Re: How to clean door shuts?
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Where I have had grubby door shuts like this in the past, I have used Autoglym Super Resin Polish and an old toothbrush to apply it, then it just wipes off. As Mark says, re-apply a little grease to your hinges afterwards.
    Cheers!
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  5. Re: How to clean door shuts?
    46 Post(s)
    Thanks Mark,
    Would this here do it? http://www.ebay.co.uk/itm/Autosmart-...item27c1e132f5
    What grease would you reccommend for the doors aferwards?
    Edit -
    Thanks Mark too!
    Might try the SRP as I have tons of it in the garage.
    What grease to use for the hinges afterwards?
    Jeez everyone replying at once!
    Thanks Jim,
    I'll try Bilberry and SRP tomorrow and see what the outcome is .. I'll get G101 if SRP or Bilberry doesnt take it off
  6. Re: How to clean door shuts?
    Dec 2007
    Belfast
    For the 1st time Mark makes some good points ?
  7. Re: How to clean door shuts?
    Dec 2007
    Belfast
    You should use white grease.
    Plenty of WD 40 first, put the grease on any moving parts with your finger
    and get it into the nooks and crannys with a half inch paintbrush.
    I presume you can get white grease from any autoparts store.
    Oct 2010
    Here And There
    White Lithium grease is made for door hindges but a friend of mine uses clear silicone lube on his. Lubricates and its not messy. Its also handy for everything. No gay jokes please lol
    http://item.mobileweb.ebay.co.uk/vie...d=300706282233
  9. Re: How to clean door shuts?
    46 Post(s)
    Lol was seeing how long it would take someone to come out with that!
    Ta for the link - will get it bought tomorrow
  10. Re: How to clean door shuts?
    Feb 2009
    Glasgow UK
    Quote Originally Posted by belfastmark View Post
    Mark, please accept my public apology, as I made a mistake.
    I started to write something else then complieted you on your points and obviously they came together.........an honest mistake, sorry!
  1. How do you clean door shuts?
    By Perry in forum General Detailing/Cleaning Questions
    Last Post: 11-07-2011, 03:46 PM
  2. Get Your Pipes Sparkling Clean With Green Glass Clean!
    By usersight in forum General Detailing/Cleaning Questions
    Last Post: 16-11-2009, 12:12 PM
  3. Fitting door guards - best way to clean surface?
    By Typ 5K in forum General Detailing/Cleaning Questions
    Last Post: 10-09-2009, 02:18 PM
  4. Volksdevil.com shuts down
    Last Post: 19-08-2009, 05:42 PM
  5. How to clean and keep clean Light Beige Phoenix Cloth interior
    By ackerman821 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-01-2008, 04:36 PM
