Thread: EPB / Rear Pad Change Question
  1. EPB / Rear Pad Change Question
    Jul 2008
    Afternoon All, I have a question about the above, mainly directed towards Martin (sorry for another thread on this, but I didn't want to hi-jack someone elses):
    I too am about to join the party of those attempting to change the rear pads themselves. I have bought an Autel-Tech EPB tool but my question is: once I have used this to electrically wind the motors off, do I need to leave the ignition on until I have fitted the new pads and am ready to electrically wind the motors back on and do their 'learn' routine, or am I safe to turn the ignition off so long as I don't touch the EPB switch etc? Then with new pads fitted, then turn the ignition back on and do the reset routine?
    The reason being that I plan to do a bit of other work (tidy up the discs, caliper etc) at the same time so don't fancy leaving the ignition on all that time.
    I have downloaded the official VW workshop manual from erWIN but doesn't mention anything about turning the ignition off while mechanically changing the pads etc.
    Thanks for any advice.
  2. Re: EPB / Rear Pad Change Question
    SE London
    Once you've wound them back, they should stay wound back until you use your Autel to wind them forward again.
    I use VCDS
    It's important to retain a good battery voltage i.e. with ignition on by connecting a battery charger. Mine's only a 5A
    max trickle type but did that as a precaution. If the voltage drops, the central electronics module will flag a fault.
    VCDS support says there's been reports of module 53 locking up and you cant recover without replacing the
    module. VW and Audi both make the recommendation
    RichardSEL
  1. B6 Passat Rear Pad Change
    By BobTheRocker in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-06-2014, 02:33 PM
  2. Passat B6 (3C) Rear Brake pad change - VCDS problem
    By dmcentire in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-04-2012, 06:50 PM
  3. Question Rear Barke Pad Change, as difficult as haynes makes it sound ?
    By TheMadhatter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-06-2011, 08:58 PM
  4. B7 Avant rear pad and disc change Problem
    By Mini Hog Dog in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-05-2011, 12:45 AM
  5. Rear Brake pad change.
    By Foxcub in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-07-2007, 03:24 PM
