Thread: Eps Light
  1. Eps Light
    Mar 2007
    Warrington, Cheshire
    The Eps Light Has Started To Come On At Irregular Intervals On My Audi A4 2.0 2002. The Eps Switch Doesn't Work When This Happens But If You Switch Off & On, Then Everything Works Fine???? No Apparent Symptoms Or Faults.
    Anyone Any Ideas???
  2. Re: Eps Light
    Oct 2006
    Maybe a dodgy ABS sensor. Usually with electronics, more so with the ESP light which illuminates a faults in the system, which includes ABS and throttle a diagnostic can be easier to identify the problem.
    A4 Avant 1.9 TDi160 for when the weather is on the damp side - Sold after 9yrs. Now A5 3.0TDI Q Sport Coupe (310bhp/480ft/lbs - Yamaha R6 for when its dry and want some 'High octane Petrol' fun.
  3. Re: Eps Light
    Mar 2007
    Thanks Dave will look into it
  4. Re: Eps Light
    Jul 2006
    outer space
    Just an idea, i had the same problem on mine, it turned out to be the ESP angle sensor which is located behind the steering wheel, but with most Audi's it could be anything!
  5. Re: Eps Light
    Dec 2006
    Quote Originally Posted by Dansk View Post
    Just to let you know... if the TRACTION CONTROL light (ESP) comes on. check that BOTH your rear brake lights work..
    If you have both rear brake lights on the TRACTION CONTROL LIGHT comes on and stays on...
    so if you had one bulb out and the other has also gone but the filerment is still making contact it could cause the light to go on and off..
    RickT
  6. Re: Eps Light
    I had a similar problem on the way to work...
    The ESP light came on as i was slowing to a stop without me realising the car had stalled with the ESP light still on, after i had started the car again the light stayed on with the car functioning normally, until i stopped at work (about two mins after) then when i turned it off and on the light went off??
    Any ideas?
    2001 Audi 1.8T 163 Quattro SE
  7. Re: Eps Light
    Mar 2007
    Thanks to you all for the help.
    As part of the car service, the brakes have been changed and fliud replaced. The light as not come on since??.
    Maybe this as solved the problem????
    Thanks again
    Paul C
  1. Polo 1.4 16V - EPC light, oil and service light issues
    By Trinster in forum Polo - Derby - Lupo - Fox
    Last Post: 19-08-2011, 08:57 PM
  2. Replies: 10
    Last Post: 28-06-2010, 09:12 PM
  3. Brake Light / Tail Light Changing Avant
    By Gazz in forum Audi A4 - Archive Topics
    Last Post: 20-11-2007, 10:23 AM
  4. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
  5. Only the high level brake light and flahing coil light
    By 49forever in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-05-2007, 04:41 PM
